KwitcherBitchin
- #16
Added the Matte Black Tailgate inserts
Love the lights! did you do it yourself or took it somewhere? If so, whats the process for tinting them as you did?Airbrushed Tail Lights and Badges
I do Airbrushing….Love the lights! did you do it yourself or took it somewhere? If so, whats the process for tinting them as you did?
I do Airbrushing….
so I sanded, Airbrushed them with a Black Candy and cleared
Did you sand the entire light lens or just the area you painted black? Also is that black paint the Lens tinting paint from rustoleum?I do Airbrushing….
Yes, entire lens was sanded with 800 grit sandpaper and red scotchbrite.Did you sand the entire light lens or just the area you painted black? Also is that black paint the Lens tinting paint from rustoleum?
thanks for the detailed info!! Lovin the look of your truck! Keep updating us with pictures as you Keep doing mods ??Yes, entire lens was sanded with 800 grit sandpaper and red scotchbrite.
White lens stayed masked off/ taped the whole time.
Black was airbrushed with Createx Wicked Black
Then 2 coats of Candy Black over entire lens
Tape was removed from white
Applied 4 coats of Spraymax Glamour Clear
Meigo100Which Etsy seller did you get the emblem overlays from?
How does the passenger side look? Is the flag the same way or reversed?Replaced the Fender Badges with the American Flag ones from Iconic.
Pretty Easy,
1.Remove badge , numerous vids on that
2. Using drill bit, drill the 5 mounting holes slowly (depending on bit size) until the outer plastic ring breaks
3. Clean Badge, remove 3M tape and stick
Mine are the Foreground (Top of Badge, Border): Matte BlackBackground (Base of Badge, Stars and Stripes): Gloss Black
IKONIC BADGES
It’s correctHow does the passenger side look? Is the flag the same way or reversed?
Yea, factory size 275/60/R20 with a 2” RC levelFactory size tires? Level?
