PB Scheduled. First Accessory Advice.
Indy443
Jesse
Oct 2, 2022
43
42
Vermont
2023 F150 XLT Powerboost
Truck looks awesome, that's what I'm going for. What would be the proper size tire to mount up once the kit is installed? Leaning towards another set of Falken Wildpeaks. My order has BAP so 20" wheel.
I like the MotoFab blocks. Very well made and easy to install. They bring the front up to near level so there is a slight rake so can still put a bunch of weight in the bed and not have it sag in the back. Ride quality is much improved with the 5100's in the rear, but I will probably end up replacing the front FX dampers for 5100's as well. This is after installing the blocks on the fronts.
Porpoise Hork
Bret
Aug 27, 2022
1,013
1,045
Houston
IT
Thanks!
Stock for the 20" is 275/60 R20 but with the level you can probably squeak by with 295/65/20's ( 35X11.50R20) and not rub, but will need to make an adjustment to the tire size with Forscan to keep the speedo correct.
Indy443
Jesse
Oct 2, 2022
43
42
Vermont
Awesome, thanks for the reply. I've just begun looking into the Forscan tutorials ... seems dooable but I'd need to get my hands on a windows laptop.
v
Thanks!
Porpoise Hork
Bret
Aug 27, 2022
1,013
1,045
Houston
IT
v
Forscan isn't all that difficult to figure out. There are plenty of tutorials on it. Just get the right cable and always make a backup of the settings BEFORE you change anything. You can pick up a W10 refurb for under 200 on Ebay.
Tripdaddy95
Jul 18, 2022
90
194
Dacula GA
2023 F-150 Avalanche Lariat SCrew PB BAP
Now that my scheduled production date has been set for 12/5 I want to begin getting a solid list of items together for the truck. What were the first accessories that you got for your truck and if you could go back and do it again, what would you add? I have an Iconic Silver '23 XLT 302a BAP being built.
I'm thinking:
1. Tonneau Cover / Bed Mat or LineX?
2. Power Cords/splitters for the 7.2kW
3. Interior Accessories? Charging devices, etc.
4. Tires (Falken Wildpeaks have been awesome on my Tundra)
5. LED plate bulbs
What Else should I be considering? Thank you-
I added
1. Wheel well liners. (Looks much better especially on light colors w/ BAP.)
2. LineX sprayin bedliner
3. Gator HR1 hard rollup Tonneau
4. LED rear license plate lights (1 month and the socket already started to burn)
5. Pedestrian sounder delete.
6. Shorter antenna
Ford F-150 PB Scheduled. First Accessory Advice. 20230107_122052
Ford F-150 PB Scheduled. First Accessory Advice. 20230107_124059
Ford F-150 PB Scheduled. First Accessory Advice. 20230107_140333
Ford F-150 PB Scheduled. First Accessory Advice. 20230107_140455
nomarhits400
Sep 26, 2022
318
332
Bellbrook, Ohio
2023 F150 Poweboost
Analytical Chemist
I added
6. Shorter antenna
Looks fantastic! Slap some black lugs on those BAP’s!
