PB + Remote Start on Cold Days?
solarity
Dec 8, 2020
174
127
Western NY
Acura MDX
I am curious how this works. Does the inside of the vehicle heat up and depending on the tempature it and the time you take to get into the vehicle? I assume that the engine will turn on, when the battery gets low and cut out again, when it is topped off?
tcp
Trieu
Oct 1, 2020
192
167
Kansas City,MO
2021 F150 Platinum, 2019 Accord
IT MGR
Here's a video testing that Schedule? Auto Climate? 2021 Ford F-150 Powerboost Remote Start
It would be nice if an engine block heater was integrated into the battery pack for warm up.
SJLCJL
Steven
Aug 30, 2020
186
82
Richmond VA
2013 F150 FX4, 2017 Mustang GT Premium, 2021 F150 Platinum
tcp
Trieu
Oct 1, 2020
192
167
Kansas City,MO
IT MGR
Exactly.. Or to add a few heating elements in the hvac ducting to help warm the inside till the engine was warm enough..
Maybe when the all electric F150 comes out... Tesla forgot which models if not all has that already but for the battery pack to keep battery temps normal if freezing or too hot.
1985ns
Nick
Jan 10, 2022
29
Ontario
2021 F150 XLT Powerboost
I find that my PB heats up extremely fast in -20c weather. The engine runs until about 50% of normal operating temp, then cycles on and off while still blowing heat in the cabin. It doesn't warm the engine to 100% until you drive.
SteveP150
Steve
Oct 29, 2021
114
120
Park City, UT
2021 F150 Lariat Powerboost
Mine heats up pretty quickly and defrosts pretty well at an outside temp of 5-10F. Pretty much always running the engine.
And so far, even once it's warm, and the battery is charged, if I'm sitting in the cold, it will have to run the engine pretty frequently to keep the heat running. I haven't figured out anyway for the heater to run exclusively off the battery, even if the truck is parked.
xtraman122
Pete
Apr 15, 2021
729
573
MA
‘21 302A PB
It does appear to rely on engine heat exclusively for the heat. When I first got the truck I was convinced it was heating up extra fast somehow, but it was only because it wasn’t very cold out yet, now that we’re in the winter months it seems to take about the same time as my old 3.5 to get heat. It definitely is weird watching your temp gauge actually go down if you return a good patch of road that it can run on just electric and it’s cold out. You’ll see it go from full temp down to half that if you can stay in electric long enough and have the heat cranked.
Oxford_Powerboost
Austin
Jul 16, 2021
849
1,105
Northern Virginia
2023 F150 Lariat 5.0
I added digital temps to my dash using FORScan. It is crazy to see how much the coolant temp swings in cold weather on the Powerboost. Seems 130 degrees is the cutoff for when it will run the engine regardless just for engine heat. Will run it back up to 140, then turn off again. Also, your electric drive power is limited until heating demand is reduced or the engine warms up further. That way light throttle will cause it to run, and it’ll just cut off when coasting or braking so it can keep engine heat a little better
