Payload Package - Unicorn?
fatbassman
Nov 20, 2023
Eastern Washington
2022 or 2023 F150
I'm in the market for a new (used) truck. I'd like it to be a Lariat, but one that can do work. Here's what I'm shopping for - but I just can't seem to find one with the payload package (7850 gvwr). Is this hard to find? Seems to be a bit of a unicorn. Anyone have that package?
2022 Lariat Mid or High
4x4
Crew Cab
6' 7" Long bed
5.0 Liter V8
Max Trailer Tow Package (53C)
Tow technology package - Pro trailer backup assist, integrated trailer brake
Max Payload Package (627)
Tow Mirrors
3.73 Rear end
36 gallon fuel tank
Onboard Scales with Smart Hitch
Kidder
Nov 24, 2021
374
352
DFW, TX
2022 F150 Lariat 3.5EB SCREW 157"
The HDPP is not available in the Lariat (or above trims). According to the Ford order guide for 2022 it's only available on the XL and XLT and for the the XLT it's only available on the low and mid.
This is from the order guide (I cut/pasted):
HEAVY-DUTY PAYLOAD PACKAGE (627)
Usage: Increases GVWR to TBD on XL and TBD on XLT for improved payload and towing
Availability:
• Opt. on XL, XLT Standard and XLT Mid
Not available with:
• 122” WB
• 145” WB
• STX Appearance Package (19S)
• XL/XLT Chrome Appearance Package (86A, 86B)
• XLT Sport Appearance Package (862)
Requires:
• 3.5L V6 EcoBoost® (998) or 5.0L V8 (995) engine
• Max Trailer Tow Package (53C) required when ordered with 3.5L EcoBoost® (998) or 5.0L
(995) Engine
Includes:
• 3.73 Electronic-locking rear-axle
• 9.75" gearset
• 36 Gallon Fuel tank
• LT265/70R18C BSW all-terrain tires (A/T) (T8C)
• Upgraded springs
• 18” silver painted aluminum Heavy-Duty Payload Pkg. wheels (64H)
NOTE: Does not include Extended Range 36 Gallon Fuel Tank when ordered with Regular
Cab for XL
fatbassman
Nov 20, 2023
Eastern Washington
2022 or 2023 F150
That explains a lot - Bummer! Any idea what the best possible GVWR is for a well optioned Lariat crew with the options I mentioned earlier?
Northguy
Jun 15, 2022
188
241
2022 F150 XLT, 2010 F150 XLT
For non powerboost
As far as I know the best GVWR is not dependent on options except box length as long as you get max tow (note 2024s may have changed this)
7050# - supercrew short box
7150# - supercrew long box
If you are talking about payload, believe some lariats have as high as 1800-1900 lbs but I believe that isn't with high package. Moonroof, tailgate step, powered running boards are big hitters. 4 wheel drive and 20" tires are so big hitters. There is a list with estimates by option if you are interested.
I went with XLT (302 high pkg) to maximize payload. Now after reading this forum know that I could have come pretty close to my payload with a low package lariat which would have given me 4A option I don't have.
hotrodmex
Feb 4, 2022
947
829
Ca
22 Lariat 500.5a
I have what you listed above in basically a 501A, with a lot of the options that come on the base 502A, and have 1948 on the sticker.
MaxTow will take about 40-50lbs off I think. You might have trouble finding a 502A that doesn't come with more heavy options like the sunroof, power steps, powered tailgate, which will all eat into that. If you got a "clean" 502A then you would come in right about the same.
Are you handy? You could turn a HDPP 301A into a 502A with some work. Had I known what we all know now when I ordered I would have gone that way and upgraded over time.
Northguy
Jun 15, 2022
188
241
This is what I used to spec my truck. Got from this forum. Note it is for a 2021 5L 4x4. Ended up very accurate estimate vs what I received.
I went with 3.5EB which cost me 35#, max tow delta vs min tow pkg is ~35# as well. For my build, 20" tires and 4x4 were big hitters but with XLT high didn't have a lot of other luxury options which I regret now given how much I like the truck.
amschind
Adam
Apr 22, 2022
583
494
'21 F150 SCrew 4x4 Powerboost
Physician
Closest you can get is 1) XLT 301 and then add in a bunch of the creature comforts or 2) get a PB and try to strip out extra weight. The PB has the second highest GVWR at 7350#, but eats a lot of that with extra hybrid stuff. The other issue is that the Max Tow 3/4 float 9.75" rear axle has been a catastrophe, and is either a roll of the dice or a ticking time bomb depending upon who you ask. I was bummed that I didn't get a Max Tow until I started to see all of the threads on the axle bolt shearing. That doesn't directly affect payload per se, but it is closely tied to max towing ratings and may be something that you choose to avoid even if it provided a higher number.
For reference, I have a 302A PB and my plan is to drive it into the dirt and replace with with a series-hybrid (e.g. Ramcharger, just well-engineered) Superduty. You may want/need a vehicle before that option is available.
fordhouston
Jun 29, 2021
126
1,303
775
Houston, Texas
2022 F150 LARIAT 501A FX4 V8
my Lariat 4X4 SUPERCREW CAB with 6.5 foot bed V8 has 1689 pounds payload capacity. pretty good amount if you ask me.
Atlee
Erroll
Sep 14, 2021
999
972
Mechanicsville, Virginia
My 2022 4x4 PB XLT 302A 6.5' box came with a CC of 1645#.
tony72cutlass's'
Tony
Jul 15, 2021
846
822
Halifax
I went and got a XLT 301A (without any payload package) and added comforts as you said (heated steering wheel being a huge one for me).
The integration was seamless and my truck has 1998LB payload and a 6' box
I did not order max tow on purpose and got the standard 9.75 rear end which appears to be bomb-proof
Ford F-150 Payload Package - Unicorn? 1700658325635
Northguy
Jun 15, 2022
188
241
I added 4A to my 2016 XLT for under $1200 installed
I would love to do that - nice work btw. Several people on the forum have done in their 2021/2. Getting the right transfer case and the right forscan programming seems a bit daunting for my capabilities (adding ambient lighting and unreal engine/climate bar to my XLT is about the limit of my forscan capabilities). Wish the there were shops that would do this mod (and front bumper sensors + adaptive cruise). 4A 2ould come in handy in the cdn winters.
  • Like
Reactions: 780
notabot
Sep 18, 2021
382
319
Americas
Yes
I would love to do that - nice work btw. Several people on the forum have done in their 2021/2. Getting the right transfer case and the right forscan programming seems a bit daunting for my capabilities (adding ambient lighting and unreal engine/climate bar to my XLT is about the limit of my forscan capabilities). 4A 2ould come in handy in the cdn winters.
Forscan change was the easiest part! Agree on 4A, it is sooooooooooooo nice to get the driveline to hook up when traction is sketchy...
Truckguy24
John
Sep 16, 2023
NC
2004 f150 2007 Mustang GT
Yeah the way to get the highest payload is definitely a two-wheel drive lower trim truck. I would love a HDPP but they are just too darn hard to find.
I'm going to stick with used now that prices are coming down, and for the past couple of refreshes, an XL STX two-wheel drive SuperCrew 5.0 has been about 2000 to 2050 lb of payload.
And a 302A SuperCrew 5.0 2 wheel drive has been right around 1950 lb. No moonroof of any kind of course.
Each one I've looked at has had a GVWR of 6,800 lbs. I've spent a lot of the past couple years digging through window stickers as trucks that fit my criteria come on the market.
I live in the south now and have only ever had to drive, so I am sticking with two wheel drive with a locker and I'll be set with high payload.
Good luck in your search. Nice to see people paying attention to payload because it sure eats up fast if you're towing even a 6,000 lb camper with gear, people etc. let alone the mods people do that they don't realize take away from the payload haha.
