Parking brake automatically coming on after truck in drive
thebigdu
Brian
Feb 22, 2022
675
709
New Jersey
2022 Lariat Sport PowerBoost
It does not auto release. I have to manually disengage. Every time.
Does it automatically disengage when you start driving? Just a tap on the throttle is all it should take to disengage. It doesn't disengage as soon as you put it in drive.. Need to apply throttle.
RocketFistMooga
RocketFistMooga
Clay
Jan 27, 2022
201
209
Pittsburgh
2022 F-150 Lariat Sport Powerboost.
Tap of the throttle and it disengages. You are correct. I feel like an idiot but in the past when I have intentionally put the parking brake on it would not auto disengage when I applied throttle. I didn’t think this would be any different
Kanuck
Don
Aug 9, 2021
1,680
1,430
Manitoba
Retired Electrician
I wonder if this park brake update is because the trucks move so much when put into park. I know mine moves a lot if on a slight down slope after I have backed into a parking spot at work. I have to release the foot brake slowly and allow the truck to roll ahead slightly.
HANCOCK
Apr 4, 2023
86
79
South New Jersey
2022 F150 powerboost
since I had the update 4.2.2 the Parking brake was engaged . I stepped on the break then release the parking brake and then it did not come on again .
ibgregr
Greg
Apr 1, 2022
DFW
2021 F150 KR Powerboost
When I put my truck in gear and tap the throttle my parking brake releases ALWAYS. It doesn't matter if I manually set it or the truck decided it needed to be set. I've never had to manually release it.
B-real
Nov 14, 2022
330
249
Utah
2023 F150 Tremor 3.5
I thought there was a setting somewhere in the menus to have the parking brake auto apply when putting the trans in P. Mine does not do this, but I swear in browsing menus I saw an option to enable it. I have a '23 with 4.2.2.1
Calson
Jul 16, 2022
712
341
Monterey CA
2022 F-150
There is a difference in having the brakes applied and having the parking brake turned on. With my 2022 truck going in reverse with a bike rack on the hitch it the truck would engage emergency braking and I needed to turn off this feature.
When backing out of my driveway I end up going uphill on the street and the truck is facing downhill and it will activate the brakes at all four wheels - not the parking brake. I need to put the truck into Drive and then accelerate to release the brakes. A little unsettling behavior but I have gotten used to it.
73
4,473
4,606
OP, your post is cryptic. After being in reverse then drive it comes on? So you're saying you're driving and it randomly comes on, or are you opening a door while in drive. The MME is far more nanny than the truck, you can't even drive with the door open without HOLDING brake off. What conditions are present that are causing it to activate?
RocketFistMooga
RocketFistMooga
Clay
Jan 27, 2022
201
209
Pittsburgh
Truck stopped. All doors closed. Put truck in park. BRake comes on
73
4,473
4,606
Ah, yeah, sometimes if you're on a slope the PB will automatically engage. Working as intended. Not sure if a little bit of movement will trigger it, like you park and then then the ABS senses a little wheel movement and triggers it. When you start it up and put it into gear and tap the gas it releases. Completely normal.
