One-Touch Up on Driver's Window not working
PatchManager
Feb 8, 2022
530
638
Colorado Springs
Firmware Engineer
The one-touch up on my driver's windows doesn't work, and I just thought that was how it was intended to work for some reason since one-touch down does work. However, I recently read the following technical service bulletin, and now think that one-touch on the driver's window should work. I likely have the issue described in the TSB.
Does one-touch up work on your driver's side window?
SSM 52074 2021-2023 F-150 - One-Touch Up/Down Window Does Not Operate Properly
Some 2021-2023 F-150 vehicles equipped with one-touch up/down front windows may exhibit a window not responding to one-touch controls, does not open all the way and/or bounces back when using the one-touch close function. These may be due to a calibration parameter in the driver door module (DDM) and/or passenger door module (PDM). To correct the condition, reprogram the DDM and PDM using the latest level of the Ford Diagnosis and Repair System (FDRS) scan tool then perform the Power Door Window Initialization procedure for both the DDM and the PDM. For claiming, use causal part number 14B291 and applicable labor times from Section 10 of the Service Labor Times Standard (SLTS) Manual.
Davidwnuc
Mar 13, 2022
480
420
Mississippi
On order ‘22 RCSB.
try this. I found it in the other forum for 2021+ F150s.
Ford has changed the reprogram procedure too. It's in the manual that is on your infotainment system. But for anyone googling before reading the manual.... (actually its a video, you don't even need to read)
Roll the window all the way up. You may have to bump it up little at a time to get it rolled up without it going back down. Then hold the switch up for 2 seconds. Then release and hold it up 2 seconds again. Worked on mine fine.
PatchManager
PatchManager
Feb 8, 2022
530
638
Colorado Springs
Firmware Engineer
Thank you. I will try that.
KingDavid
Dah
May 15, 2023
197
110
Fort Lauderdale, Florida
2021 F150 XLT SCREW 4×4 5.0
Thank you. Mine just acted up out of nowhere today and this solved it.
CarbonizedSTX
May 16, 2024
SoCal
F150 STX 4x4
Much appreciation for the instructions on how to fix this issue. Worked like a charm and helped me from going insane.
