Oil Drain Plug
Tobstertx3
Feb 13, 2022
472
462
Fulshear, Texas
2022 F150 Lariat
Hi. Looking for recommendations for an Oil Drain Plug. Looking for quality item that will keep for years without any leaks.
RedTXV
Apr 16, 2021
669
541
Houston, TX
2021 SQ Limited
What’s wrong with what you have? Are you looking for something special?
Grafx36510
Rob
Apr 18, 2022
827
932
NY
2019 F150 XLT 302A/2022 F150 Tremor 402A
The guy that everyone b*&%ches to at work...
My take is he’s looking for something like a fumoto valve.
Kodiak
Apr 27, 2022
37
1,511
1,966
Virginia
I'm going with this. I will easily be able to direct the drain tube through the cat theft plate I plan to get.
ValvoMax Oil Drain System
PPK
PPK
May 25, 2022
117
144
OKC
2022 F150 502A, 1947 CJ2A, WK2 Limited
Not to go against the grain.. but I add a magnet to each of my oil drain plugs.. gives me some comfort as to how much wear is occurring between changes.. I epoxy a 1/4"x1/2" round magnet into the plug, usually I drill a 5/16" hole deep enough to hold it.. the stock ford drain has this already - all you need to do is epoxy the magnet in place. good luck however you go.
Ford F-150 Oil Drain Plug Magnetic_Drain
Kodiak
Apr 27, 2022
37
1,511
1,966
Virginia
If you feel like making something you could try a Franken Mag for the magnets.
Mach725
Nov 1, 2021
90
42
Chicago
22 XLT Sport 302A 2.7L Space white
Are the 2022 2.7 the plastic plug or metal threaded typical drain plugs?
XLT22
Nov 12, 2022
245
159
GA
2022 302a XLT
It’s plastic. Save your money and buy a 25 pack of #208 Viton o-rings from Grainger supply or any industrial supply house. Last check it was $14. Change it every oil change is what I do.
