The column to the right of the "Unit/ Location Averages" is just under my 5k interval. The oil weight was just slightly under SAE 30 with 5k miles.If this lab report is was from the 6K interval and you typically change at 5K my guess is you are fine at 5K.
However, without seeing your last 5K report (or two if the differ much) it's difficult for us to offer meaningful input.
I actually don't. My driving is around 90% highway (65 miles daily), the majority of the idling is remote start and hovers around 5-10 mins per day. I do have a heavier foot and I think the turbos are shearing the oil sooner.Do you do a lot of stop and go along with towing heavy load? If any are yes, I would change the oil sooner, around 4k miles. FWIW, I"m using Pennzoil Platinum 5w-30. Full synthetic because they handle heat better. IMHO, turbo's can cook the oil pretty good and we have 2 of them.
I had same viscosity issue with my 2.7 at 20k miles (4500 on the oil). No fuel dilution or coolant. I had Mobil1 EP, I’m wondering if that’s what caused low viscosity? I did have several short trips during my 4500 miles. Did you have any similar oil or type use?Hey everyone, wanted to share my most recent oil analysis. When I purchased my truck from the dealer, it had around 350 miles on it. It was originally delivered to a dealer in Jacksonville and I purchased it in Miami, hence the miles. Understandably, I was worried about the break in and how it was driven for those 350 miles. My last ecoboost was totaled in an accident and this was at the peak of chip shortages. It was 1 of 3 in the lot (June 2021) so I took my chances. I have religiously maintained it with Motorcraft semi synthetic oil changes every 5K, except for this last run at 6K. Many roadtrips and towing sessions later, I am absolutely in love with the truck. With the exception of OTA/ battery issues, the truck rides and drives like a dream. The only concerning part for me is the oil viscosity but it does not seem to be an issue at this time.
No, I have towed some heavy loads but only for like 300 miles out of the 6000, the rest was mostly highway miles on motorcrafy synthetic blend. I just think these turbos chew up the oil real good. After learning this, I wouldnt change my oil based on the oil life monitor. It seems like 4k-4.5k will be the sweet spot for me.I had same viscosity issue with my 2.7 at 20k miles (4500 on the oil). No fuel dilution or coolant. I had Mobil1 EP, I’m wondering if that’s what caused low viscosity? I did have several short trips during my 4500 miles. Did you have any similar oil or type use?
I shared this and agree with you and using the same oil. 5k oil change interval here. Might spend the $30 during my ~13k oil change for another lab test to confirm the comments about break in compounds.No, I have towed some heavy loads but only for like 300 miles out of the 6000, the rest was mostly highway miles on motorcrafy synthetic blend. I just think these turbos chew up the oil real good. After learning this, I wouldnt change my oil based on the oil life monitor. It seems like 4k-4.5k will be the sweet spot for me.
Im only not surprised because there's a thread with 47,000 posts on the Ram Hemi forum about finding the best oil producing the best UOA. (Those hemi eat lifters with meh and down oil). PUP and redline are the bee's knees over there. They ever were able to get the Pennzoil oil engineer/ rep to post for a while.Anyone seen this?
I've always used Mobile 1 in my new vehicles and Walmart Supertech in my old used vehicles.
I'm considering moving to the "High Mileage" versions based on viscosity and wear reduction as evidenced in the test.
Also, a direct Penzoil only comparison here. Surprising results!
You have a line for that? Google is being stubborn.Im only not surprised because there's a thread with 47,000 posts on the Ram Hemi forum about finding the best oil producing the best UOA. (Those hemi eat lifters with meh and down oil). PUP and redline are the bee's knees over there. They ever were able to get the Pennzoil oil engineer/ rep to post for a while.
definitely hard to find.You have a line for that? Google is being stubborn.
