Off-road Tire Recommendations for 20" Sport Set-up?
Visier
Feb 2, 2021
Greenville, SC
2021 F-150 XLT
Product Management
I do some occasional off-roading for camping and overlanding in the southeastern US. My new truck has the 20" aluminum wheels with the sport appearance package and FX4 set-up (XLT trim). I love the way it looks stock, except for the conservative tires which I'm sure to replace well before they wear down.
This question is probably more for 20" wheels in general, but:
Will the 20" wheels hold up well to moderate offroading with the right tire? My concerns are that I might not be able to gain enough sidewall to absorb shock and protect the bead from slipping after airing down, and that the design of the wheel is convex enough that it will easily mar up under moderate offroad use. My prior offroading experience is limited and was in a truck with 15" wheels and plenty of tire, so I am not sure how close these 20" wheels would cut it.
Basically: Should I just have a separate set of wheels and tires for when I intend to go offroad, or should I throw offroad tires on the 20" wheels and be confident they will hold up well if I don't go too crazy.
If anyone has any first-hand experience, I'd love to hear your thoughts!
Ford F-150 Off-road Tire Recommendations for 20" Sport Set-up? IMG_5685
05RubiconLJ
Matt
Aug 6, 2020
40
881
755
Arkansas
As with any wheel, of any size, your not going to want to beat it like a rented mule. I would not have any reservations about the 20" wheel being tough enough for what it sounds like you are going to be doing with the truck. I would suggest going with an all-terrain tire of your choice, but in a bit more robust size. I am taking off my 275/60-20's and replacing them with 295/60-20's. That is going to result 1.5" of sidewall height and about an 1" of increased width. An inch doesn't seem like much when you look at it on a tape measure, but that additional bulge will protect the wheels better when both inflated and give you more tire contact when underinflated (also more protection).
It is my understanding that a 295/60 will fit without leveling, but if your concerned, you could go with the factory size or bump up to a 285/60 or 275/65 tire and be good to go.
brnt
Nov 29, 2020
141
137
UT
'21 Lariat
I run two completely different sets of wheels on my Jeep Grand Cherokee. It works really well--neither the road set nor the offroad set are compromises. Also, steel wheels are cheap:
https://www.roadreadywheels.com/products/2004-2020-18x7-5-ford-f150-steel-wheel-rim
If you're committed to getting new tires already, for an extra $400 you can bash the cheap steelies instead of the fancy OEM alloys.
ilkhan
Sep 29, 2020
80
46
Iowa
2012 Ford Escape Limted
Add a mild level and 35s and you'll have enough sidewall. Make um wider and you'll get sidewall to protect the wheel face.
Fogf150
Francisco
Feb 24, 2021
Miami, florida
2021 F150 XLT
Management
It is my understanding that a 295/60 will fit without leveling, but if your concerned, you could go with the factory size or bump up to a 285/60 or 285/65 tire and be good to go.
Excuse my ignorance new to all this, just got 2021 XLT , XLT Sport, want to add beefier tires but NOT level or lift etc,,, stock is 275/60/r20,,,,,,,,, so you mention one could add 285/65/20 (thinking of BF Goodrich Ko2),, and NOT level or lift and NO rubbing???? THanks,,,
serinjune
Feb 23, 2021
69
52
PNW
'21 Lariat 3.5L EB FX4
I wish I had done some more research on this before going in on some stock size Falken Wildpeak AT3W's. I'm super happy with the tires as is, but it seems with just a leveling kit, I could have had a larger tire. I think this just gives me reason to go with a leveling kit and new wheel/tire combo now ?!!
Hartz
Feb 24, 2021
45
52
Vancouver, Canada
2021 F150 XLT
I am going to be following this thread and see what results people are posting. I too wish to keep the stock 20" rims because I just love the look of them. I do NOT love the look of the Dynapro AT2's though and want to upgrade them without a level. Was looking into the K02's, AT3W's or Ridge Grapplers.
05RubiconLJ
Matt
Aug 6, 2020
40
881
755
Arkansas
Here are some comparison numbers 'Stock vs. Alternate Size'. In my early post, I believe I fat fingered the 285/65, that number should have been 275/65. I will correct it. It is possible it could fit, those are big wheel wells, but I can't say for sure.
I would consult your tire purveyor as to potential rub of any size you choose. I'm adding a 2" level, so my options are bit more open. Shop all the applicable sizes, as some sizes cost significantly more or less.
Ford F-150 Off-road Tire Recommendations for 20" Sport Set-up? 1614208104357
Ford F-150 Off-road Tire Recommendations for 20" Sport Set-up? 1614208179820
Ford F-150 Off-road Tire Recommendations for 20" Sport Set-up? 1614208228467
Ford F-150 Off-road Tire Recommendations for 20" Sport Set-up? 1614208269821
Ford F-150 Off-road Tire Recommendations for 20" Sport Set-up? 1614208339103
05RubiconLJ
Matt
Aug 6, 2020
40
881
755
Arkansas
To circle back on my comments above, below is a chart based on Tire Rack/Discount Tire pricing, which shows size, price, and available tire choices (Nitto, Falken, Yokahama, ect). I used BFG's as my base for pricing, as most folk are very familiar with those. This chart also serves as a reminder to price check your local dealer to get the best deal.
Ford F-150 Off-road Tire Recommendations for 20" Sport Set-up? Capture12.JPG
Hartz
Feb 24, 2021
45
52
Vancouver, Canada
2021 F150 XLT
Thanks so much @05RubiconLJ for these charts. They are incredibly helpful and much appreciated. Here at my local tire shops, the K02 285/60/20's are $100 cheaper per tire than the 295/60/20's. Crazy. Currently I'm in the research phase - factoring in change in feel, mileage, longevity and of course look to my stock tires.
StangTech
Dec 13, 2020
90
54
Jersey
2021 F150 Lariat FX4, 5.0L
Just grabbed my tires today, going on Tuesday with a slightly larger 285/60/20 on stock Lariat chrome wheel and no leveling kit...I like the look of the Dueler and also it won't give up much ride quality.
Ford F-150 Off-road Tire Recommendations for 20" Sport Set-up? IMG_3172
Ford F-150 Off-road Tire Recommendations for 20" Sport Set-up? IMG_3222
Norris McCarty
Norris
Jan 21, 2021
171
211
San Angelo Texas
21 F150 Lariat 4x4 PB 7.2k FX4 17”Raptor Beadlocks
Own a RV dealership
The best recommendation for 20” off-road wheels and tires is to sell them and buy 17” or even 18” wheels and tires.......if you are seriously wanting to use your truck off-road.
people-call-me-chris
Feb 19, 2023
46
Phoenix, Arizona
F-150 Lariat SCrew 4x4 short bed
Visier... what did you end up choosing? Thx
Walter Townsend
Walter
Aug 27, 2023
109
98
Nelson, BC, Canada
2021 F150 Lariat FX4 Off Road Fishing Edition 5.0
Owner Operator Starlight Tool Services Ltd Millwright/Welder/Machinist/Electronics tech
Careful, with this, good chance with the year and trim level of this truck that it will have minimum rim size of 18" so getting 17" rims will be a problem with them not fitting the brake rotors.
