Hauk
I currently have a 2021 RWD 3.5 EB with a 9.75" open diff. I use this to launch ~7000lb boat. It typically does just fine, but sometimes if the ramp is wet/slick, I have to be particullary careful to prevent wheelspin. I am afraid that sooner or later I am going to get in a bind, so want just a little more traction available, for peace of mind. This is my only use case for needing more traction and do not go off road.
With this in mind, I think I would prefer a factory e locker, and would like to get it as close to "stock" as possible. I know alot of people despise the factory e locker, but I think it will be sufficient for my rare use purposes. The ford e-lockers are also more affordable than aftermarket, and can be had for around $400 new. My truck has the green plug and wiring where you would plug the elocker in. I will have to drill a hole in my rear end case to install the connector bulkhead to hook up the e locker solenoid wires. At this point if I have to, I can hook up a toggle switch directly to the solenoid circuit to engage the e lock, but I would prefer to have a more OEM solution. Does anyone know what else would be necessary? Would it be just buying the new drive mode selector knob, pinning the connector and doing some ForScan coding, or is this more involved?
