mmdpg
- Mark
- Feb 23, 2021
- 2
- 155
- 131
- Massachusetts
- 2008 Bullitt Mustang, 2021 F-150 Lariat
- Retired
So this is not a huge deal but it is annoying.
When driving on the highway above 55 MPH I can hear a sporadic tapping sound, to me it sounds like a large cable or tube against metal or thick plastic, coming from the passenger seat or passenger footwell area. Not that loud, not in time with turning wheels or driveline.
First I thought it was wind related because it only occurs at higher speeds so I got under the truck and glued or aluminum taped down all the loose insulation, sound deading or heat shielding I could find under the cab. I re-attached the small holder on a tube going into the transfer case. I turned up the stops on the hood to reduce any vibration, glued down a panel to the firewall that was loose and I taped down the antenna cable in the fender. I even removed the short aftermarket antenna to see if that was the cause and it made no difference.
Then I thought it was vibrations causing the noise so I checked everything I've added to the cab (air pump, first aid kit) to make sure there are no rattles, put cloth tape on two wires in clips behind the glove box, poked, prodded and wiggled everything I could find under the dash, under the seats, on the doors and still getting the noise.
It doesn't sound like the noise people have described from the mirror panels on the doors (to be sure I did remove those panels and tightened the nuts there anyway).
It doesn't happen at low speeds over rough roads or bumps.
Any ideas?
Any ideas?
