Noco Genius Users - Pulsing Green
AndreB
Andre
Jan 1, 2024
86
69
Province of Quebec, Canada
2023 F150 Lariat 502a Star White Metallic 157" WB
A few different threads have covered a lot of information regarding permanently installed trickle chargers.
https://www.f150gen14.com/forum/threads/battery-maintainer.21728/#post-417668
https://www.f150gen14.com/forum/thr...-the-screen-steering-wheel.21917/#post-422518
Make sure that the negative lead is on top of the BMS (Battery Monitory System), not directly installed on the negative battery pole.
Also, depending on the the capacity of the battery being charged, it might take a few days before the green light goes solid green (not flashing).
Living in a winter cold region, I installed 2 male/female Noco plug adapters permanently on the plastic part below the right and left headlights (below the head lights and on top of the metal bumper). This plastic part is easily removable (two small bolts inside both front wheel wells, then unclip at clipping points). I drilled a 2 inch hole on either side of the plastic piece (their is a section where their is more space "below the headlights"). With this setup, I can plug in an extension cord for the charger (on the right side "passenger side" of the truck) or the engine block heater (on the left side "driver side" of the truck) without having dangling wires from the truck. Other benefit is I have access to the charging function even on the road, away from home.
https://no.co/gcp1
Ford F-150 Noco Genius Users - Pulsing Green IMG_5109
Ford F-150 Noco Genius Users - Pulsing Green IMG_5110
Kodiak
Kodiak
Apr 27, 2022
45
2,019
2,754
Virginia
https://no.co/gcp1
This is outstanding! Well done and thanks for posting.
FrankSJ
Frank
Sep 1, 2022
80
108
SouthJersey
22 F150 Platinum 3.5 RR BAP, 2015 Mustang GT PP
https://no.co/gcp1
Nice setup. I was tired of popping the hood and did something similar with the noco adapter, went to the rear wheel well liner, just have to remember to unplug before I hit the road.
Ford F-150 Noco Genius Users - Pulsing Green IMG_1954
gb7FRz26
Aug 23, 2021
136
114
North Texas
2021 F150 XLT SuperCrew Short Bed, 2010 Prius
You can also leave it attached. I do it with mine. Leaving it attached was the only way the most recent update would install OTA for me.
+1 on leaving it attached.
My NOCO 5 is attached with ring terminals to the battery and gets plugged in every single day.
