Buyer2021
Feb 9, 2021
44
2,660
4,831
TX
retired!
The more I look at it, I think they may have grabbed the wrong axle housing for that graphic. There is no way to attach the hubs to that axle.
Your right. I may be entirely over-reaching what can be concluded from these diagrams in ford.parts.com. :unsure:
Hans Moleman
Mar 3, 2024
265
159
SF Bay
2023 XLT 302A Powerboost FX4 Sport
The recall affects trucks built up to Dec 25, 2022.
What changed on 2023 models built after Dec 25, 2022?
I just bought 2023 powerboost with max trailer tow package and build date of April 2023 and it is not under the recall.
122
8,416
9,703
2022 307a PB
Looks like it's changed to 3 bolts from 4.
The axle to hub pressure now looks to be coming from the new parts with the likes-to-shear bolt being done away with entirely.
Henfield
Dec 15, 2021
528
405
Usa
2021 XLT Screw 5.0,4x4,302Asport,
Based on experience with other brands, Recalls can be extended to include vehicles not originally involved or targeted with the recall.
Jeff1024
Nov 18, 2021
421
485
Louisville, KY
2022 F150
Welp add me to the list. Thought i may have gotten lucky. Went on a quick run up to the grocery store and heard a squeak from the passenger rear.
17500 miles on a 2022 3.5 max tow
Ford F-150 NHTSA Safety Recall (23V-896) on 113,000 F-150 Trucks with Trailer Tow Max Duty Package 1000000611
Ford F-150 NHTSA Safety Recall (23V-896) on 113,000 F-150 Trucks with Trailer Tow Max Duty Package 1000000610
Unicorn
Marc
Nov 6, 2023
Quebec City
2022 F-150 XLT HDPP
Pilot
According to the recall, if the bolt shears, the hub cannot depart the vehicle. Hence, the culprit bolt is not there to retain the hub. Earlier I asked how the hub is retained, sounds like only the bearing assy is sufficient without the bolt. Please someone enlighten me :)
scott011422
Scott
Feb 17, 2022
861
643
60178
The hub bolts on just like the front wheel hubs do.
10,768
20,919
The wheel is bolted to the hub. The hub is bolted to the axle tube with 4 huge bolts.
The Bolt that shears is just a "locator" bolt for the relationship of the two mating splines. Keeps the axle from working its way inboard about 3/4".
Unicorn
Marc
Nov 6, 2023
Quebec City
2022 F-150 XLT HDPP
Pilot
Ok maybe I am not using the proper wording then. The rotating part that has 6 studs, on which my wheel is bolted, - that part - cannot be bolted to the axle tube. Else it could NOT rotate! So, what is it that holds that rotating part when the bolt (subjected to the recall) breaks?
scott011422
Scott
Feb 17, 2022
861
643
60178
just the bearings, same as the front
Buyer2021
Feb 9, 2021
44
2,660
4,831
TX
retired!
Ford F-150 NHTSA Safety Recall (23V-896) on 113,000 F-150 Trucks with Trailer Tow Max Duty Package WHEEL RETENTION
Buyer2021
Feb 9, 2021
44
2,660
4,831
TX
retired!
Just FYI / further info .... the "Hub Assembly" (with 'captive' wheel flange) pictured above is considered by Ford to be a 'non-serviceable' part. The Workshop Manual has no procedure for separating the flange from the hub, no procedure for maintaining or adjusting bearing(s) within the hub, no procedure for separately replacing the integral toothed ABS 'tone ring' seen on the inboard side of the assembly above.
IOW, if the bearings or any other part of that assembly are damaged or out of spec, the entire assembly as pictured is to be replaced.
EDIT - the wheel mounting studs can be replaced (press out/in) separate from the rest of the assembly as pictured.
Hans Moleman
Mar 3, 2024
265
159
SF Bay
on a related note, if the axle bearing goes bad in the future, it seems easy to change. Buy the hub assembly with the axle bearing already in it. Remove 4 hub bolts and 1 axle bolt then the whole hub assembly comes out.
Unicorn
Marc
Nov 6, 2023
Quebec City
2022 F-150 XLT HDPP
Pilot
I truly appreciate your explanation. Bearing play can only be detected when axle bolt is absent. Therefore, if bearing have some play, it will cause an undue stress on the axle bolt.
