- Bruce
- Jun 19, 2021
- 5
- 10,784
- 20,951
- Coastal Texas
- 2022 F150 KingRanch Powerboost
I was just describing what you had pondered and the idea it planted in my mind, as feeble as that might be.Are these TTY? They appear to seal the axle and the hub together to mitigate gear oil leakage. My idea is a whole other configuration entirely, not just a washer.
If it is NOT the over-torquing of the OEM bolt that is injuring the shank, and then leading to eventual shearing under additional stresses, then it must be solely those additional stresses on an otherwise healthy bolt.
(Unless the OEM bolts are simply crap?)
So my idea is just to cushion those forces in play on the bolt itself a little.
The hub/axle mating surface is what carrys the transfer of torque to the wheels. I don't think that design or the materials used aren't up to the task, as long as the axle is kept at the intended location relative to the hub.
