LostBoy
Aug 10, 2022
97
51
Louisiana
2021 Space White F150 XLT 5.0
thats for some of the headlights from certain months in 2022 i believe. They flicker
Porpoise Hork
Bret
Aug 27, 2022
1,003
1,040
IT
No flicker recall for mine. Build date 1/12/22.
https://static.nhtsa.gov/odi/rcl/2022/RCLRPT-22V686-3271.PDF
Vehicles may exhibit a park lamp flickering that does not meet the steady burning requirement of FMVSS 108.
2022-2022 Ford F150
Production Dates : MAR 11, 2022 - JUL 23, 2022
77,804 F150 vehicles are affected.
Description of the Defect : Parking lamp flickering may occur during any of the three following scenarios.
1: When the customer manually selects the “position lamp on” mode.
2: When the customer manually selects “Headlamp On” Mode.
3: When the customer is driving in automatic headlamp mode, and the environment gets dark enough to trigger “Night Mode”, which turns on the headlamp and parking lamp function.
The frequency of operation of the LED driver module is currently 200Hz. At 200Hz, the lamp is susceptible to flickering due to insufficient capacitance on the capacitor when operating between 2.95 and 3.14 volts and the lamp has LED string voltage greater than 12.5 volts.
The remedy component is an LED driver module (NC5A-13B626-FB) with updated software. The software update increases the frequency of operation of the LED driver module from 200Hz to 400Hz. The lamp is susceptible to flickering due to insufficient capacitance at the 200 Hz voltage on the capacitor when operating between 2.95 and 3.14 volts and a lamp with LED string voltage greater than 12.5 volts. Increasing the frequency of operation to 400HZ reduces the required capacitance more than 50%. This allows the lamp to operate without flickering.
fordhouston
fordhouston
Jun 29, 2021
140
1,537
911
Houston, Texas
2022 F150 LARIAT 501A FX4 V8
interesting.. i personally haven’t seen this problem occur on my truck yet. I’m curious to know what it looks like.
Porpoise Hork
Bret
Aug 27, 2022
1,003
1,040
IT
If you have ever seen a car turning in front of you with cheap LED lights, that flicker effect they do out of the corner of your eye? That's pretty much what happens with the F150 with the 200 Hz coding.
Zyvin
678
867
SC
2021 F150 Crew, FX4, Lariat
2022-2022 Ford F150
Probably the most in-depth answer ever on here, lol!
Now can you tell me how to keep my bathroom vanity lights from flickering while my washing machine is running? lol
Porpoise Hork
Bret
Aug 27, 2022
1,003
1,040
IT
Lol. Give it my best shot.
I'm guessing you have LED bulbs in the vanity. If so, then may be due to the brand of bulb. Cheap off brand LED bulbs have crappy capacitors in them. The washer is probably tied to the same circuit as the vanity. The increased draw or noise feeding back in the lines is causing it. Try higher quality bulbs, or fixture. If it's an AC/DC fixture, try installing a higher quality power supply or LED driver.
Zyvin
678
867
SC
LOL, yea I believe it is just crappy/cheap bulbs. I replaced them recently to get a higher color temp and it started right away. They will flicker pretty much anytime my washing machine "agitator" changes direction. The washing machine is literally on it's own circuit, which is weird. I am sure everyone on the forum is liking this thread, lol.
Porpoise Hork
Bret
Aug 27, 2022
1,003
1,040
IT
lol yeah.
Sounds like combo of line noise from the washer and cheap bulbs to me. Had a similar issue with the off brand walmart bulbs and the deep freeze. Went to GE bulbs and have not had an issue since.
crazywayne311
Wayne
Aug 24, 2022
713
654
Hampton Roads, VA
2022 SCrew 157" Agate Black Lariat 502A
CTMO
lol yeah.
was going to say...cheap LEDs cant handle even the slightest variance in voltage and when there is voltage fluctuations, it'll show through the cheap LED's. 100% right it usually occurs when said bulbs are on a circuit being used by something that tends to pull some draw (washer, microwave, fridge compressor) electrician or smart? haha
Northguy
Jun 15, 2022
238
301
2022 F150 XLT, 2010 F150 XLT
My order to delivery was almost 9 months. 5 months to build (built date was in June) and then sat 3.5 months in a railyard 2.5 hrs away from my dealership. Believe this is the reason my truck and lots of others that had similar delays to mine. Good to finally know the specifics.
athenslb57
Apr 12, 2022
85
118
AL
22 F150
Yep, I have seen this issue while my truck was running and I was standing in front of it.
fordhouston
fordhouston
Jun 29, 2021
140
1,537
911
Houston, Texas
On a side note.. i wonder if this would fix the LED DRL flickering issue for those who had turned the brightness all the way up to 100%.
towpro
will
Jul 3, 2022
125
84
Fl
23 Lariat Powerboost
Wonder if this is going to stop my glarefree from working
