Need help!
ddeford78
Dwight
Jul 18, 2023
Nevada
2023 F150 Platinum Powerboost
I was updating my 2023 PB through FDRS when my laptop crashed. I was right in the middle of the IPMA update when it happened. Now I'm unable to restart the update because it says unable to communicate with module. When I restart FDRS it gives me multiple DTCs and I have multiple warnings on the dash. I have restarted the computer, unable plugged and replugged the cables, etc. I currently have both batteries disconnected and I'm going to retry in the morning. Have I bricked the IPMA module or is there a workaround? Any help would be appreciated.
NotMyName
John Doe
May 12, 2022
116
123
2021 Bronco First Edition, 2022 F150 Platinum
Reach out to our great member Jesse-infotainment. He will be your best source for a fix.
Kanuck
Don
Aug 9, 2021
1,736
1,507
Manitoba
Retired Electrician
Also download and install TeamViewer. Jesse may need that to remote in and do his magic.
Jesse-Infotainment
Jesse
May 27, 2021
3,749
5,941
Since there is a post Ill go ahead and post this so if anyone ever has this happen.
First thing is its going to be ok. Module is fine.
Second thing is shut truck down and lock it and walk away for 30 min or so. Let the truck go to sleep
Once you come back open up FDRS
Select IPMA from the Module tree.
Select Programmable Module Installation
Select NO when asked if the original module is installed
Then follow the prompts and it will now see the module again and start to flash it.
The PMI will also update it. SO you will not be required to do the update afterwards. Once the PMI is complete youll be all set to move on.
The IPMA is a group update meaning it will roll into the PSCM, CCM, and CMR if you have it.
So once the IPMA is complete you can skip the other modules IF those have already been updated in not it will roll through and you can let it complete them all.
Edit - If you get stuck on configuring module dont let it sit for hours. after a few mins and it doesnt complete, abort out of FDRS by closing the app with the X at the top right as you would for any windows app. When you click the X it will bring up a scary abort are you sure click hell yes I am and the same on the next one until youre out.
Then open FDRS and you can rescan and the IPMA update should be gone.
Jimalt
Jim
Nov 25, 2023
33
West Chester, OH
2021 Star White Platinum PB 157” FX4 Max Tow
Service
This guy should have a cape with a big S on it! Thanks and a handshake for being so helpful to everyone!
tpatt27
Taylor
Mar 9, 2024
texas
Thank you @Jesse-Infotainment for posting that fix! This exact same thing happened to me yesterday and I was in full panic mode lol. Got the IPMA fixed and everything else up to date in FDRS, but still seems like it doesn't have all the features it should (unreal theme, cameras at speed, bed camera card, Alexa).
Its been a struggle since I bought this truck...If anyone has recommendations I would greatly appreciate it.
Jesse-Infotainment
Jesse
May 27, 2021
3,749
5,941
Unreal is optional.. wont be enabled automatically.
Unreal is
7D0-02-02
XXXX XXX1 XXXX
BED CAM CARD IS
7D0-01-03
XXXX XXXX XFXX
CAMS AT SPEED
IPMA
706-02-02
XXXF XXXX XXXX (THIS IS FOR 360 ONLY)
XXX1 XXXX XXXX (REAR CAM ONLY)
Alexa Ill ahve to remote in to enable that. I dotn give those out publicly
tpatt27
Taylor
Mar 9, 2024
texas
Unreal is
7D0-02-02
XXXX XXX1 XXXX
BED CAM CARD IS
7D0-01-03
XXXX XXXX XFXX
CAMS AT SPEED
IPMA
706-02-02
Oh ok, I was thinking all of it should have been enabled after updating everything without using forscan, thank you. You seem to be the wizard here with all the sync stuff, I don't want to bother you but I have a few questions, would you mind if I PM'd you?
Jesse-Infotainment
Jesse
May 27, 2021
3,749
5,941
No problem.
ReverendQ
Kevin
Mar 26, 2023
198
214
SoCal
Website
www.linkedin.com
@Jesse-Infotainment , well, I somehow got myself in the situation others have with IPMA update. Thanks for posting this fix. I am implementing it now. Any feel for how long the IPMA PMI will take? And will it require FDRS Alignment Procedure, whatever that is?
Jesse-Infotainment
Jesse
May 27, 2021
3,749
5,941
THe PMI will take the same amount of time the Update would. 1.5 - 3 hours
no need for the alignment or calibrations
ReverendQ
Kevin
Mar 26, 2023
198
214
SoCal
Website
www.linkedin.com
Thanks again Jesse and sorry to bother you once more but....It is coming up on 4 hours. I just checked the truck and it was OFF and the PC showed this. I turned the truck back Key ON Engineer OFF but it IPMA PIM appears stuck. Truck appears to be all good but some settings i.e. 5MPH tolerance need reset. Please advise. Do I need to be patient or cancel out of this screen?
I Aborted it, shut down FDRS and the truck, cleared DTCs, restarted FDRS and all is well, all green and no updates showing needed. I will check again but if you are so inclined, please verify no modules to udpate. Thanks!!!
Ford F-150 Need help! 20240405_193314
Jesse-Infotainment
Jesse
May 27, 2021
3,749
5,941
Yeah if it gets stuck on configuration just close out fdrs.. it’s fine..
It’s fine nothing is wrong. Happens to everyone just about.
