DT444T
Jake
Dec 29, 2021
419
376
21 AMB Powerboost Lariat
Meat servo
Sure, what do you care. After all you're just driving "someone's built-wrong custom order". ;)
I'm not certain I understand what you are implying.
DBL R
Jarred
Oct 11, 2021
456
639
Washington
2021 F150 powerboost
PA
My payload on my 2023 PB is only 1050. Picking up my new travel trailer tomorrow. I hope the tongue weight is under 700. The factory says 604. But I am sure it will be higher.
1050? Ja-hesus
Mash150
Dale
Jan 26, 2021
509
365
North of the 49th
21 King Ranch, 157, SQ , PB
Is that the door sticker on your truck or a CAT scale weight. I can’t see a fully loaded PB that low straight from the factory as you have added after market accessories. My 21 KR PB came in at 1320 ,same 157 and only lacking a few options and added much of the same accessories afterwards.
Cobraman428
Cobraman428
Jerry
Dec 21, 2021
29
546
992
Tampa Bay Florida
2021 F150 Platinum PB 701A MT FX4
VP of IT
My almost fully loaded Platinum payload is 1323#s. 1050 seems low and may be the lowest I've seen.
Samson16
Kyle
Mar 24, 2023
3,341
3,325
Orlando, FL.
Aviation systems
I said: "He wouldn't spend money for Max Tow and then run 87 in it. Must be a typo."
You said: "I would. And do"
I said: "Sure, what do you care. After all you're just driving "someone's built-wrong custom order". ;)"
Referring to the line in your classic signature that states: " Bought someone's built-wrong custom order after I blew up a 2019 Ranger in the mountains 1800 miles from home while towing. "
Having to explain means it was yet another poor attempt at humor on my part.
The octane debate just won't die so I was trying to make light of it.
Penywisexx
Scott
Apr 3, 2023
Oklahoma
2021 F-150 Lariat Powerboost
I tow a dump trailer with my ‘21 PB for work occasion. I live in Tulsa where it’s pretty much flat. I just put my truck into Eco mode when I tow in flat areas and easily get 17-20mpg with a 50/50 mix of highway and city driving. The trailer weighs about 2500-4000 pounds typically when I’m towing and is about as aerodynamic as a brick.
Cobraman428
Cobraman428
Jerry
Dec 21, 2021
29
546
992
Tampa Bay Florida
VP of IT
I've read mix things about towing in ECO compared to Tow/Haul. I may try to tow in ECO on return trip from the dealership. I know a lot about what happens in Tow/Haul mode, lock out gears, hold shift point, no Electric motor etc. I've only towed my TT a few times so I'm still trying to get avg MPH with my setup. Thanks for the feedback on ECO..
DBL R
Jarred
Oct 11, 2021
456
639
Washington
PA
Ford really did the customers dirty by not allowing the heavy duty axel on lariat trims and above. Clearly they were worried about typical spec’d trucks cannibalizing f250 orders.
122
8,481
9,779
2022 307a PB
Max tow is the upgraded axle -- If you want to convert the PB to HDPP, simply swap out the rear springs. PB's frame is 2nd only to the raptor in terms of strength.
If you don't have max tow, a complete rear axle w/ HDPP springs is all that's needed. That's it :)
UGADawg96
Feb 28, 2021
3,436
6,039
JAX, FL
Maybe you've posted this elsewhere, but what are your thoughts on putting RAS on the PB with MT. Does it provide similar results as the HDPP springs in your opinion ?
122
8,481
9,779
2022 307a PB
Personally I'm not fond of how the RAS works only interacting with half of the spring stack. I prefer quality airbags myself as they can be adjusted in-cab, underway and when completely unloaded can dropped down to ~3 psi which all but removes them from the equation. Plus with some valves it can also be used to inflate tires or have a trailer channel.
For heavier duty applications, a panhard bar will really help lock in the rear end's side to side movement for increased handling.
DBL R
Jarred
Oct 11, 2021
456
639
Washington
PA
Max tow package actually provides a lower payload vs trailer tow package, according to ford literature.
122
8,481
9,779
2022 307a PB
Of course it does, it has at least 22lbs of heavier rotors. We're not talking about stickers, we're talking about the limiting factors for running heavier payloads.
DBL R
Jarred
Oct 11, 2021
456
639
Washington
PA
My point being that the actual HDPP package provides increased payload with documentation from ford that will hold up in court. The rest of the pieced together HDPP provides less payload (on paper), and that the true HDPP option isn’t available for lariat and above.
122
8,481
9,779
2022 307a PB
Oh, right. Can't forget all of the folks regularly going to court and having to drag their documentation with them. That's right up there with everyone picking up their million dollar lottery checks. Any guess which one occurs more? On that note I need to finish my lightning mitigation faraday cage around each one of my fruit trees. Gotta protect against those regular lightning strikes, ya know?
Keep in mind where the burden of proof resides, and your basic rights. The 2 most important rules any lawyer will tell ya, #1 don't talk to the govt and #2 don't talk to the govt. (including its agents).
