ProHERO
So this morning I noticed a clicking noise coming from outside in the back and I immediately thought it was a rock in the tire. When I got home my jaw dropped when I saw a screw in the tire. I decided to remove the tire, replace it with the spare and get it repaired at the tire shop. There’s not many level roads where I’m at so I reversed into the garage. My garage is level except for a small lip in the front that I couldn’t clear because the truck is too big. So I lifted the truck with the jack, got the tire off and as I went to put the spare on, the truck started rolling forward. The truck rolled about 10 feet by the time I got inside to get on the brake. I was in shock and pissed that this happened because on a regular basis I do my own preventative maintenance and I’ve removed and replaced my tires several dozens of times. As I thought about what happened, I know for a fact the car was in park but I didn’t have the parking brake on which I normally do and I didn’t have chocks in the front.
After thinking about this more, shouldn’t the transmission in Park have prevented the truck from rolling? I couldn’t have accidentally left it out of park as the shifter prevents leaving the vehicle in any gear. I verified this safety feature was working and I’ve never had an issue with the transmission. I even parked in reverse on a steeper hill and once placed in park it didn’t roll.
In the end, I learned a hard lesson. It could have been a lot worse. There was very little damage except to the metal plate behind the brake rotor which I bent back to shape. Although I say it was a rookie mistake, I should have double checked the parking brake was set and used the chocks. This was completely preventable. Please everyone stay safe out there!
