Demps
- #46
I had another failure. Sat in the truck, turned on Wi-Fi, let the truck idle, and released the update. It failed because "Update could not complete. The system will try again with the next update." Widget failure code was OTAM_E1016, which appears to be a common failure code, especially on the Mach E forum.Just as a data point, 2.6.0 has failed 4 times on my truck per the Android Widget by @kennelh on the other forum.. January 2021 build, 5.0 302A. Trying to decide whether to go to dealer. This thread is very helpful, thanks all.
Not sure what failed, download or update, but recently the truck went into deep sleep. Called the dealer about deep sleep and OTA failure and set up an appointment to check out the truck.
Surprisingly, the dealer called back to say there is a module that needs to be updated. We shall see.
