Loading/unloading a 450 lbs safe from truck bed
thudnblunder
Nov 15, 2021
487
428
Bay Area, CA
2022 F150 PowerBoost
Cloud Software Architect
Hey all,
I'm picking up a safe and planning to bring it home in my F150 Platinum - how much weight can the powered tailgate take in the open position? Can I safely slide the 450 lbs safe and tip it out over the opened tailgate onto a dolly without damaging the tailgate? I plan to use 3/4" plywood and some carboard to spread the load and protect the edges.
  • Like
Reactions: sbi
Probity
Nov 3, 2022
39
29
Covington LA
2018 F150 Scab XLT 2.7EB 2wd
Questions questions.....
1) How you getting the safe INTO the bed - loading dock, forklift, ?
2) How you getting it OUT of the bed - crane/engine hoist, other?
thudnblunder
thudnblunder
Nov 15, 2021
487
428
Bay Area, CA
I'm assuming the store I'm buying it from is using a forklift to load it in.
I'm getting it out by rolling it on PVC pipes to the edge of the bed off the tailgate, and then lowering it to the floor with two people with cargo straps.
My question is if the tailgate can take 450 lbs on the tailgate edge in the open position as the weight is slid off.
UncleFester
Feb 23, 2024
86
76
Great Lakes
2023 F150
I have broke many mounting ears off the tailgate along with cables overloading the tailgate with construction materials. The specs say 600 lbs so you will have to test the numbers.
JohngaltinOC
Scott
Mar 11, 2021
208
143
Orange County ca
2021 F150 lariat EB
Finance
I'm not enough of a scientist to calculate the kinetic energy about to be unleashed. You might want to be concerned about the dolly, as much as you are the tailgate. 450lbs falling 3 feet has got to be a meaningful number. Like you, I would also be concerned about what happens to my tailgate after the point of no return. I think I'd come up with a better plan A personally. 😬
bcb97
Ben
Mar 9, 2023
89
62
Madison, MS
2022 F150, 2020 Expedition
I don't think it would be a problem. I did this in my old truck and me and a buddy slid it out, let it slowly come down off the tailgate onto the ground. However, I did not do it on my powered tailgate.
powerboatr
Robert
May 9, 2022
136
3,186
3,603
North East Texas, Piney Woods
2022 F150 King Ranch 4x4
Retired Navy Senior Chief
450 seems like alot
when i got my safe i used the car hauler trailer and had them lay it on a side
when we go home we used the Egyptian method you are using round things and rolled it to the end and tipped it up onto a furniture dolly.
no hands were harmed
you could brace the tailgate with a few 2x4s double stacked on the tailgate hard points and then a center support
i am 226 and i hold ok
guess you could stand 3 guys on tailgate and see what breaks
my guess is the gate will hold, but no funny stuff
get it across and off
Probity
Nov 3, 2022
39
29
Covington LA
From your '22 OM, removing a power tailgate isn't near as easy as a manual one, but does appear do-able with a couple people (didn't realize the tailgate itself weighs ~100 lbs). Getting the safe IN w/a forklift should be drama-free and minimal/no load onto the tailgate. Getting it OUT - I sure would think about removing the tailgate.
amschind
Adam
Apr 22, 2022
776
691
'21 F150 SCrew 4x4 Powerboost
Physician
I did this back when I got my safe. My advice: hire people. The limiting factor isn't your tailgate, it's your discs and your ligaments. Paying a Ford tech to replace a tailgate is expensive, but it's dirt cheap compared to what spine surgeons charge.
JohngaltinOC
Scott
Mar 11, 2021
208
143
Orange County ca
2021 F150 lariat EB
Finance
Remind me not to mess with you and your friend. Someone here put a 600lb limit out there, but I might consider just removing the tailgate altogether and using multiple 4x4's to make a ramp and slide it down that way... Just spitballing.
79
4,921
5,117
2022 307a PB, Mach E GTPE
Yup
x1000
Rent a back is sooo much easier and cheaper in the long run.
Rinn69
Sep 21, 2023
178
239
N Central IOWA
19 Ranger; 24 F-150 XL 4x4 RCSB ordered
Retired USAF Medic
A wrecker or any truck with a boom would make it an easy and safe unload.
ryanc111
Ryan
Feb 19, 2021
335
366
Bozeman, MT
Leadfoot Powerboost
Depending on the safe you may be able to remove the door thus reducing the weight being moved at a time.
thudnblunder
thudnblunder
Nov 15, 2021
487
428
Bay Area, CA
Some great ideas and insights here, thank you all.
To be clear I’m not planning to lift it out of the bed nor drop it three feet on to the floor.
My plan was to bring it to the edge of the tailgate and then use cargo straps to control sliding it down. And then a dolly after that.
I'm 250 lbs, I guess me and my friend can sit on the tailgate to load test first lol
This video shows the process I had in mind but I think that safe was lighter.
