LED REFLECTOR to LED Projector swap discussion.
NutNugget
Brennan
May 19, 2021
Louisiana
I tried this swap yesterday. I have LED reflectors want the projectors would even be fine without the bending feature just love the look better. Few things to note. Standard LED REFLECTORS have 3 plugs from the harness. As the LED projectors have one central plug on the back of the headlight. The pins are also different between that main plug. I can plug them up, headlights work and daytime running lights turn on. Side markers, turn signals and high beams don’t work. The photo of the connector with less wires coming out are the reflectors and one with more are the projectors. If anyone makes/can make a harness to make these work would be wonderful lol. I assume the turn signals and side markers don’t work because there’s no where to plug them in from the reflectors harness and pins are different/ missing on the harness for the reflectors to produce that ability in the headlight. Also there’s TONS of wires inside the actual headlight itself on the Projectors. (See photos). Didn’t want to short anything out so no way for me to text each wire to know what wire/pin location to add to my existing harness to give them power.
Ford F-150 LED REFLECTOR to LED Projector swap discussion. D546DE28-CC3F-4915-8197-8189A42186C4
Ford F-150 LED REFLECTOR to LED Projector swap discussion. 6705E50B-C03B-4147-A01B-4DDD8DA97AE9
Ford F-150 LED REFLECTOR to LED Projector swap discussion. B5FB12E7-2407-42EB-871A-C43808671DDD
Ford F-150 LED REFLECTOR to LED Projector swap discussion. B128D4D9-7F0D-4129-A060-D98F21806DEF
Ford F-150 LED REFLECTOR to LED Projector swap discussion. 24C51084-3761-4107-A191-208E9393FCD1
Ford F-150 LED REFLECTOR to LED Projector swap discussion. 428ACE52-72F3-489F-8D67-ACD68A1A01ED
Ford F-150 LED REFLECTOR to LED Projector swap discussion. 04EDAC8A-F370-49E1-8059-322F5E4152C2
Ford F-150 LED REFLECTOR to LED Projector swap discussion. F262D02B-7763-4094-B8D9-CE832A6D88D8
Ford F-150 LED REFLECTOR to LED Projector swap discussion. 8570A87D-04A9-4F80-8036-A8CAC20C22F7
Ford F-150 LED REFLECTOR to LED Projector swap discussion. 5D83DCB8-1344-41CC-963F-C8B31DD54BE3
Ford F-150 LED REFLECTOR to LED Projector swap discussion. EDCA9067-DB9F-4384-A151-9B82B555F412
Ford F-150 LED REFLECTOR to LED Projector swap discussion. 7CEAA2B2-738B-4A62-904E-81E37C814C02
NutNugget
NutNugget
Brennan
May 19, 2021
Louisiana
Really hoping someone can figure this out as I also love the look of the projector and hoping to be able to swap.
Same..... it’s going to take another harness but I believe it can work for sure. Also just need to know what PIN connector does what. If I know that I could just splice my current harness into the empt PIN holes
1,989
Does the wiring diagram label the wires? I know that from another post, the projector LEDs interact with a few different modules.
https://www.f150gen14.com/forum/thr...r-to-projector-led-headlights.1859/post-36147
Another option is to find a projector equipped truck and probe every wire. You would at least be able to figure out the high beams without much trouble.
As for the leveling, someone should be able to make a stand alone adapter that can level the headlights manually by simulating the factory signal.
The dynamic bending is slightly more complicated, as it adjusts with the speed and steering angle.
discussed here:
https://www.f150gen14.com/forum/thr...-dynamic-bending-headlights-502a-and-up.1094/
NutNugget
NutNugget
Brennan
May 19, 2021
Louisiana
discussed here:
This is what I was able to get. It’s a diamgram showing each connector position for the LED projector connections. The bending would be great addition but honestly I just want them to work at least normally for now lol
Ford F-150 LED REFLECTOR to LED Projector swap discussion. DA39169D-600C-4EC7-9F4B-74FD0DF7E6BF
Ford F-150 LED REFLECTOR to LED Projector swap discussion. 4E590842-CE08-4221-926E-7EDFD113C796
Jcway16
Joe
Aug 21, 2021
35
Long Island, NY
2022 F-150 XLT
I just picked up a set of these headlights for my ‘22 XLT 302a and I’m hoping someone comes out with a plug-n-play harness to get these to work
Majorplane
Oct 11, 2021
552
382
Louisiana
2016 F150
any follow up from the OP on this? I too like the look of these and am interested in swapping. I don't necessarily need the bending function, but would like for the rest to be working properly
Jcway16
Joe
Aug 21, 2021
35
Long Island, NY
2022 F-150 XLT
Yes, boostedgreygoose does make a harness, but for some reason all of the sellers of harnesses are out of stock right now.
Precision Retrofits also makes a harness. Check out the details on the HCM and such.
neldiaz
nel
Aug 6, 2022
puerto rico
f150 2021
army
where you able to get em workin?
neldiaz
nel
Aug 6, 2022
puerto rico
f150 2021
army
where you able to get it working? I got the same problem. XLT reflector to full led from lariat conversion, Im kind of stuck right now because of this.....
JScaro
Nov 4, 2021
306
318
Georgia
2021 Ford F150 Lariat 501.5A
Beer Drinker
@NutNugget
Any updates on this? I'm trying to source of plugs so I can build something like this.
Ford F-150 LED REFLECTOR to LED Projector swap discussion. 1663348818002
Anon678
Oscar
Jul 11, 2023
Ford F150 2021
Did anybody get this sorted? Has anyone tried just hardwiring from quad headlights to projector? I know leveling functionality would be gone but I'm just trying to get my headlights to work with the basic functionalities.
Thanks in advance
