LED projector upgrades
OleMustyBag
May 21, 2023
110
92
Spring, TX
2023 F150 XLT 5.0, 2015 GMC Acadia, 1963 ChevyNova
Was looking in the HCM module forscan options, it has an option to change over to PWM signaling. Haven't played with seeing if it accepts PWM signaling or not (assume nothing). I suspect it will. That makes it even easier to control. Generic PWM controllers can be had for $2/ea.
Very simple now -- 3 wires to the head lights, B+ ties in at the spade connector hiding on the bottom of the image. Full dynamic / glare free operation
What is the info on where to get those knobs you used? Did you have to change any settings in Forscan?
Hawsa
Sep 19, 2022
78
84
Utah
2021 302A F-150
The HCM firmware thing did not make sense to me either. But they keep telling me that. So your DRL dim setting is zero? Do your DRLs come on when the truck is parked and running? What line in the BCM is that you’re referring to? Mine are not set at zero but very dim the flash from dim to bright. If I turn the brightness at park up too high then I get no blink.
Yes my turn signals/hazzards still work fine when I have my drls off, the car is in park, etc..
120
8,226
9,453
2022 307a PB, Mach E GTPE
I must have missed this post.
you can turn off the LED outage detection with forscan to get rid of the hyper flash.
for the front blinkers the value would be
726-40-02 0000-xxxx-xx
Yes, that was implemented right after that post and added to my sheet of changes for the 8" IPC.
Ford F-150 LED projector upgrades 1738625745103-gd
OleMustyBag
May 21, 2023
110
92
Spring, TX
Sorry I just saw that post you posted.
Do you have a part number on that potentiometer that you used?
120
8,226
9,453
I wouldn't use the one I used. I'd find a good 20k one sourced anywhere but amazon.
beaver24
Jun 11, 2023
Missouri
21 F150 Lariat
Engineering Technician
I have a 23’ and I had to combine the wires to make the turn signal work. I also found out if you have the brightness increased on the low brightness DRL the blinker won’t work because there is no difference between the low and high brightness. However since I did mine I heard someone had figured out that the HCM in the raptor has different firmware. I think it was Ryan B maybe? So now I could have just swapped HCM and done the Forscan changes. I am not sure but don’t think that applies to the 21’.
Have you done the DRL brightness increase on yours?
@OleMustyBag So, what are your settings for:
726-38-01
726-38-02
726-42-01
726-43-01
beaver24
Jun 11, 2023
Missouri
21 F150 Lariat
@Hawsa
I know you handwired your harness, but in the end was yours pinned out 100% to oem chart for led-p lights? I thought you originally said you had to repin some.
OleMustyBag
May 21, 2023
110
92
Spring, TX
@hawas
I know you handwired your harness, in the end was yours pinned out 100% to oem chart for led-p lights? I thought you originally said you had to repin some.
I didn't really hand wire the harness, I bought an adaptor harness from Ryan. Then I modified it to tap the blinker wire over to DRL. I will have to look up those forscan values I don’t have them written down. But also I turned on glarefree so some might be different.
120
8,226
9,453
Headlights are Mx150s so it's easy to Y a pin if you need to. I cut off the blinker/parking light connectors and added pins and put them into the factory harness -- each one has a ground that's not needed, also one is a redundant blinker on the 3 wire.
Ford F-150 LED projector upgrades 1739059542532-um
Final HCM integration harness
Ford F-150 LED projector upgrades 1739059887800-zh
vs initial test harness
Ford F-150 LED projector upgrades 1739059976550-3x
beaver24
Jun 11, 2023
Missouri
21 F150 Lariat
Update for anyone else doing Raptor Headlights on Lariat or Platinum:
I have a Lariat 502A and installed Raptor P-LED headlights. I ordered the marker splice adapter harnesses from Starkey Products,Inc.
I ordered a few Molex terminals and rewired them with some Deutsch molded diodes to combine turn signal wire into the DRL wire. Turn signals, hazards, everything works now. Thanks for everyones information!
Ford F-150 LED projector upgrades 20250220_224316
Ford F-150 LED projector upgrades 20250220_225212
