ThinblueF-150
its not bad
That is awesome. Thank you. Do you happen to have a part number for the steering wheel you used? I am about to buy one but I don’t want a used scuffed up one on eBay. So you purchased the one that has the adaptive cruise button and swapped the buttons out? Thank you so much.![]()
its not bad
So I purchased mine from Cmo_5.0 on Instagram and it was direct swap but you can’t swap over your buttons it’s easyThat is awesome. Thank you. Do you happen to have a part number for the steering wheel you used? I am about to buy one but I don’t want a used scuffed up one on eBay. So you purchased the one that has the adaptive cruise button and swapped the buttons out? Thank you so much.
I contacted him on IG. Thank you.So I purchased mine from Cmo_5.0 on Instagram and it was direct swap but you can’t swap over your buttons it’s easy
I did the swap on a 2020 F15 without any problems or complications. I purchased my New take off leather steering wheel off of Ebay for 300 bucks.Air bag was no problem disconnect negative battery cable and wait about 15 minutes to remove it. The wiring inside of the Steering wheel was a plug and play. The only difference I can forsee is if the replacement sterring wheel has the HEATED option. The sterring wheel will work ,the plug in may be different. In that case you can reuse the switches off of your existing steering wheel. I say GO FOR IT! Looks so much betterAny XL/STX guys in here do the leather swap yet? I noticed the steering wheel lists for about $500 and change give or take but it's currently backordered. Was wondering if anyone managed to find one and swap out theirs yet?
IMO it's the only thing the interior of the STX is missing.
Thanks!ML3Z-3600-JA
I've seen for about 321.00 new
ML3Z-3600-JA for 175 please let us know where. I thinking of doing the swapThanks!
$175+tax new in Canada. Just bought one yesterday using my Ford pass points, plan to install on my 300a on Saturday.
yes, disconnect battery for about 15 minutes.What does powering down the srs system consist of doing? Just disconnecting the battery?
