Lane Centering While Towing?
Old Bear
Jerry
Nov 13, 2022
215
256
Clarksville, TN
2023 Ford F150 King Ranch Powerboost
Information Technology
Does lane centering work when a trailer is connected? If not, is there a FORScan code to activate it?
fordtruckman2003
Apr 28, 2023
4,551
3,701
Indy
2021 F-150 FX4 Lariat
The ping pong effect would get interesting with a trailer. Too much fun for me. I don't see why it would not work unless there is something in code to prevent it when trailer plug detected.
hitchhiker
May 19, 2021
87
136
Maine, USA
2022 F-150, 1965 F-100
Software Engineer
Hands-on lane centering works while towing. Bluecruise does not.
redline
Kyle
Oct 11, 2022
463
510
Calgary
2022 f150, BMW X5, BMW M3,
Sales
I did not like it on icy roads last winter , I would not want it turned on when I am pulling a trailer.
kevdog0710
Kevin
Feb 11, 2022
1,202
862
South East Pennsylvania
2022 F150 Lariat Supercrew
Union Carpenter
It works, but trailer sway is the issue.
I have a WDH with sway control, I turn off lane centering and the onboard trailer sway control when towing.
{tpc}
Anthony
Feb 12, 2022
570
299
Berkley, MI
Ya the lane centering will start off ok, then get progressively worse as it overcorrects every time, resulting in trailer sway.
If you have a very flat perfect road with no passing vehicles, it sometimes works for a bit. But it’s not worth the sway that could and would happen.
Groovicles
Mar 14, 2022
312
269
2022 F150 XLT 302A PB Max Tow
Finance
I'm curious, why would you turn off the onboard sway control while towing? Wouldn't the WDH + sway control bar + onboard sway control be the safest way to tow?
kevdog0710
Kevin
Feb 11, 2022
1,202
862
Union Carpenter
The onboard sway control fights the WDH, creating sway. I notice every time I get to highway speed, goes away as soon as I turn it off. I have a friend with a similar trailer, same truck and WDH, his experience is the exact same as mine.
Davexxxx
Mar 25, 2023
67
1,249
1,313
MO
This is apparently a trailer and weight specific issue.
Some don't have to turn off sway control and some can use lane centering while towing.
The only constant I know of, if it is one, is how heavy, with heavier being worse, to the point of being unusable.
Could be the weight, could be the set up of the WDH.
One of the benefits of the weigh safe hitch I'll be using on my first big tow with this truck later this week, is hopefully being able to more precisely dial in the weight bars and be able to use both anti sway and lane centering.
I'll let ya know.
kevdog0710
Kevin
Feb 11, 2022
1,202
862
Union Carpenter
I'll let ya know.
This is the 1st time I've seen Weight Safe. Looks very similar to the 4 point Equalizer I use.
Davexxxx
Mar 25, 2023
67
1,249
1,313
MO
Functions the same but way easier to adjust (no washers, just loosen and then retighten 2 bolts) and the built in scale to dial it in depending on the load.
You can literally adjust it each time.
Aron
Aron
Jan 26, 2022
731
903
Virginia
Civil Engineer
Lane Centering works, but it's sometimes uncomfortable. With zero wind, I've had it work a few times satisfactorily. However, with a little cross breeze, the trailer gets pushed, which causes lane centering to engage, then the trailer gets pushed, which causes lane centering to engage, and you can end up bouncing back and forth between the lines (just a little, but enough that it feels like you're ALWAYS fighting your steering wheel to keep in control--it's not a comfortable feeling.)
Every time I tow, I turn it on at the beginning to see if it'll work, but frequently turn it off pretty quickly. I do keep the adaptive cruise turned on, so I really appreciate that you can turn one or both systems on and off independently.
Big Smokey
Doug
Feb 9, 2023
Calgary, Alberta, Canada
2022 4X4 Platinum 7.2 KW Powerboost
I do not use lane cantering as I find it over corrects. I do use adaptive cruise and it works well. I also use sway control but find little difference on or off. I have a Blue Ox Swaypro WDH setup and I really like it.
GadgetB1
Brian
Aug 25, 2021
33
Ohio
2021 Ford F-150
Software Engineer
Did a 1800 mile trip last month towing a travel trailer and lane centering works sort of… It induces trailer sway at times from constant small corrections (ping pong effect) and at other times there is no issues and I can use it for a while. Its really nice when it works.
