Jack points
jcaspar
Feb 23, 2021
445
414
Sacramento CA
2021 F-150 4x4
Had my first chance to use the jack kit with a flat I changed at work over lunch. Worked well and the kit is nicely packaged and has a great lug nut wrench. Able to do it in my suit and tie with minimal mess. The spare makes me think that some dark wheels would look great with the Carbonized Gray.
konoplya
Jun 26, 2022
77
USA
22 F150
so if i wanted to lift the entire back of the truck at once and they don't want to use the differential itself, how would i do it? i've done it once on the truck to rotate the tires and i put the jack right under the center of the differential..
powerboatr
Robert
May 9, 2022
134
3,076
3,448
North East Texas, Piney Woods
2022 F150 King Ranch 4x4
Retired Navy Senior Chief
i would NOT do that
use the extension that grabs under the leaf springs
Jersey devil
Jan 18, 2023
169
129
No. Georgia
2022 XLT
Probably have to use 2 jacks or back up on a set of ramps.
powerboatr
Robert
May 9, 2022
134
3,076
3,448
i'm not sure which part you're referring to
on rear lift jacks they have arms/adapters that can touch the area on the lower leaf spring mount plates between the bolts
konoplya
Jun 26, 2022
77
USA
22 F150
i'm still not quite sure which area you mean. but would that lift the entire back up or just one side?
powerboatr
Robert
May 9, 2022
134
3,076
3,448
spreads across to lift entire rear
its usually on lifts you drive up on
Carphunter
Apr 28, 2021
39
Central Wi.
2021 F150 Stone Gray SCAB XLT 2.7 4x4
Here it is:
In that rear jacking picture... are they showing it jacking on the axle itself... or something in front of it? it's odd they show some sort of block or pad on the jack under the pumpkin... but they don't show the same sort of thing for the jack under the axle (or wherever they are trying to illustrate it's sitting).
jcaspar
Feb 23, 2021
445
414
Sacramento CA
2021 F-150 4x4
Axle itself.
Forever Blue
Dec 7, 2020
64
1967 Fairlane GT, 1993 Ranger STX, 2019 Flex, 2021 F150 Lariat
There are ”punched out“ arrows on both frame rails front & rear. For a 2 post lift or a floor jack use the areas immediately below the arrows on the frame.
Carphunter
Apr 28, 2021
39
Central Wi.
ya, i knew the frame points... just that axle diagram looked a little off. anyway...snows are on :)
