Is slight shaking / shuddering normal when the gas engine starts from a stop?
Hans Moleman
Mar 3, 2024
208
103
SF Bay
2023 XLT 302A Powerboost FX4 Sport
When taking off from a stop, there Is slight shaking / shuddering when the gas engine starts automatically. It’s the kind of shaking when a regular gasoline cranks and starts up. I’m wondering if this is normal with the PB or even with hybrid vehicles in general since it’s my first one.
When I’m moving along and it transitions between EV to ICE, I don’t feel any shaking.
at all.
stevemcbo
Steve
Nov 28, 2023
58
40
39565
2023 F150 FX4 Powerboost
Yup. normal for mine. Regular ICE start and stop does the same thing. Drive it and enjoy.
Ford F-150 Is slight shaking / shuddering normal when the gas engine starts from a stop? IMG_20240123_162912452_HDR
Hans Moleman
Mar 3, 2024
208
103
SF Bay
thanks for letting me know. With the odd noises PB makes and the 10R80 harshness sometimes I’m not sure what is normal.
WA_502A
KC
Jan 1, 2024
Spokane, WA
2022 Ford F-150 Lariat 502A
Mine does it as well. I always assumed it was normal but it would be nice if it didn't.
BUCKETCOWBOY
DAN
Sep 5, 2023
29
FLORIDA
2023 F150 XLSTX 5.0 4X4
PICKLE MANUFACTURER
auto on auto off feature needs to be abandoned ill never buy a vehicle with one
99
7,017
7,809
2022 307a PB, Mach E GTPE
at all.
Could you describe it in more detail? The one issue I've had w/ ice engagement would be it coming on while it was 1-3 skip shifting. I had 1-3 skip shift removed with the tune and no longer have to deal with that issue. The skip shift was an issue for certain spots where I pull out / clear a drive, the second I was ready to go it'd 1-3 w/ ice engage. Just a poor set of circumstances aligning when I wanted power making it 1-3 at low RPM annoying.
Porpoise Hork
Bret
Aug 27, 2022
1,202
1,247
Houston
IT
How many miles were on it when you got it? If more than say 100 then use forscan and reset/clear the adaptive transmission tables. Once cleared put it in Sport or Tow mode and drive it calmly avoiding hard acceleration on surface streets for a good 30 or so miles before getting up on the freeway. It will shift like crap at first as it relearns the pressures needed and your driving style. It'll take about 250 miles to complete the adaptive learning cycle and by the end it should have relatively to very smooth shifts with little to no 2nd gear skips.
You can also do this if/when you tow something and forget to put it in tow mode which can cause the transmission to pick up some funky shift or drive-ability behaviors as well.
Hans Moleman
Mar 3, 2024
208
103
SF Bay
it gives a little shake as soon as I hit the gas from a stop and the ICE starts up right away , still in 1st gear.
ive seen mine shift 1-2 on harder acceleration and 1-3 on light throttle acceleration. Regardless of if shifts 1-2 or 1-3, it up shifts pretty smooth. I never experienced any harshness when it’s upshifting through any gears.
However my harsh shifting happens during downshifts like from 10-7 and from 3-2. Also I feel a light clunk intermittently when I feather the throttle while it’s in 10th gear.
Hans Moleman
Mar 3, 2024
208
103
SF Bay
I bought it with 500 miles. Thanks for the suggestion. I’ve been holding out on Forscan but I guess I should finally get.
Old Bear
Jerry
Nov 13, 2022
212
255
Clarksville, TN
2023 Ford F150 King Ranch Powerboost
Information Technology
Mine also does this. I just attributed it to the combination of transitioning from hybrid to ICE and shifting all at the same time. I ignore it now. Shifting from 1st to 3rd happens from gentle starts, with adding just a little more throttle (smoothly) will grab 2nd gear. Mostly I let the truck do what it wants to do.
99
7,017
7,809
This could be a variable of the low RPM mode where direct injection shuts off and only port injection is used? It's an emissions thing.
Hans Moleman
Mar 3, 2024
208
103
SF Bay
I received my OBDLink EX adapter and have newbie questions.
1. The instructions it has to be in ”Key On” mode but not running. However on the PB with push button start you go into accessory mode without holding the brake while pressing the start button. Is the accessory mode the correct mode to be in with push button start vehicles?
2. In the process of clearing the adaptive tables, should I also clear the PCM?
Main thing is I’m trying to fix the 10R80 shifting clunkiness.
dafish
Sep 11, 2023
325
192
Midwest US
22 F-150 PB KR SCREW, '18 Lariat SCREW
Mostly retired IT Pro - Cyber-IPT
Mine does it too, but one has to be being picky, My wife would never notice. Ecoboosts have a slight stumble when they are cold. As I recall it's it's condensation in the intercooler. Goes away almost immediately. The start shudder, assuming we're talking about the same thing, is sorta like that - Pretty faint, normal for the truck, not something I worry about.
