Interior "A pillar" handle removal?
wmuav8tor
Matt
Feb 12, 2021
42
37
SW Michigan
2021 F150 XLT
Airline Pilot
I'm trying to hardwire my dash cam into the interior fuse box down by the passenger's feet.
How do you remove the trim piece in the center of the handle pictured to access the screws to remove the pillar trim? it looks like there is a small hole that you should be able to just stick something into it and pry it out but i've tried several objects and they have all bounced out of the hole without moving it at all so I think i'm doing something wrong. (drivers side is pictured cause I was on that side when I decided to take the picture)
Thanks
Ford F-150 Interior "A pillar" handle removal? EA195B7C-9261-46B0-935E-B53350E0B8C0_1_105_c
imgone10
Paul
Sep 7, 2020
119
131
Boston
07 FJ Cruiser, 15 TRD Pro 4Runner, 2021 Lariat.
Construction / US Army 84-96
I believe you remove the outside part of the handle to access the bolts. There is a small little spot in the cover you use to pop it off.
imgone10
Paul
Sep 7, 2020
119
131
Boston
wmuav8tor
wmuav8tor
Matt
Feb 12, 2021
42
37
SW Michigan
2021 F150 XLT
Airline Pilot
That is what I have been trying to do, but I was using keys and then when that didn't work tried a screwdriver but neither worked. I'm sure I have pick hook somewhere so i'll give that a try once I find/buy one lol. thx
BaySide1
Kevin
Apr 29, 2021
59
34
Worcester, MA
2021 F-150 Lariat Super Crew 5.5Ft Bed
Medical Equipment Repair
no need to take it out. just run the wire across the top of the plastic pillar and tuck it in. that's all I did.
KISS Method
Wakevictim
Stephen
Jan 24, 2021
95
109
Williamsburg
2021 XLT 3.5L eb
Military
It’s two bolts behind the cover on the handle. It’s easy to do but use caution if you’re not only using your fingers. It scratches really easy. Also, once the bolts are out, it easily comes out. There is an airbag behind it as well, so use caution if your just tucking the wire if you don’t take it off.
Wakevictim
Stephen
Jan 24, 2021
95
109
Williamsburg
2021 XLT 3.5L eb
Military
If you push hard enough toward the middle of the handle like arrow 1 shows, there will be enough room to grab where arrow 2 points to pop it off. That’s how I did it to replace my factory tweeters.
Ford F-150 Interior "A pillar" handle removal? 347AD4CD-DE2B-4E9C-9783-351A4AC03618
fayby
Aug 17, 2021
2021 F150 Lariat
Don’t have to take it off, simply use a trim tool to tuck the wire in.
