Installing Onboard Scale?
ROBB1
Justin
Oct 10, 2021
287
362
NC
2021 F150 Tremor
Not quite relevant to the thread, but I have a question about this.
I am adding the LHS ride height sensors to my 501A with projector headlamp swap to get the auto-level. Does this mean that my ride height sensors will not work unless I calibrate them with FDRS? I am not adding a VDM, I am wiring the ride height sensors directly to the HCM as is done with all 502A trucks without CCD/scales
I think no, only because there are no "calibration values" in the HCM as-built like you see in the VDM. I do not know for sure though.
dolsen
Aug 19, 2022
2,076
1,898
KY
2022 Rapid Red 701A
In the F150 non-ccd or scales, there are only two height sensors. One front and one rear both on the drivers side. They send a analog signal to the HCM for leveling. No VDM.
CCD or Scales get 4 sensors (the sensors are different for CCD vs non-CCD) they feed into the VDM, they are calibrated in the VDM, and for leveling the HCM gets the "height" info over the CAN bus from the VDM.
Looks like my educated assumptions were correct lol. I’m glad when it happens like that
dolsen
Aug 19, 2022
2,076
1,898
KY
2022 Rapid Red 701A
I certainly hope that’s the case. In the little bit of Jessie’s brain I’ve been able to pick, he’s never mentioned having to calibrate the sensors, and he’s usually pretty thorough, so (here comes another educated assumption) I don’t believe there’s calibration needed SPECIFICALLY for the auto level from the ride height sensors. After all, it *should* be able to auto level based off of positional difference between the two height sensors.
antho
Anthony
Sep 20, 2021
778
733
Houston, Texas
2021 801A Raptor
Ford F-150 Installing Onboard Scale? 1675210347102
ROBB1
Justin
Oct 10, 2021
287
362
NC
2021 F150 Tremor
From my perspective its a sound assumption. The headlamp assemblies can be manually leveled, so if done in a relatively level truck condition, the HCM then simply looks at the difference in analog output front to rear and adjusts accordingly. Auto leveling seems like a relatively unsophisticated calculation compared to scales or the next level up CCD. In those cases fronts to rear and side to side become a factor.
Taco1588
Brian
Jan 30, 2023
15 Tacoma, 21 Titan P4X, 23 F350 Lariat (on order)
So if im understanding correctly, the non CCD and scales just have these 2 sensors. CCD and scales have 4 sensors and there's one at each corner right? Do we have a diagram showing the 4 sensors and where they go?
redline
Kyle
Oct 11, 2022
298
302
Calgary
2022 f150, BMW X5, BMW M3,
Sales
I am not sure why you would want the scales most useless option in my truck … the next one will not have it , they take away 25 lbs of payload and don’t do jack shiet. Save your money
ROBB1
Justin
Oct 10, 2021
287
362
NC
2021 F150 Tremor
Correct.
They go directly to the VDM. When I have moment I will dig up the diagram.
LD50
Jan 7, 2022
96
85
IL
2019 Raptor, 2022 Lariat on order
If you're asking where the 4 sensors are physically mounted, they're not. The sensors on the CCD trucks are the CCD shocks.
Taco1588
Brian
Jan 30, 2023
Right what about the trucks that dont have the CCD, theres still 4. Im asking because I have a 2023 Superduty coming and Scales is an option, but CCD is not an option on superdutys. So ford has another way of doing scales without CCD. We have figured out that the 4 sensors still go to the VDM, so its probably a different VDM, or different programing.
DK4
Jan 23, 2022
320
363
USA
Truck
There are sensors just above the leaf springs. There is a good pic of the front sensors earlier in the thread, the rear sensors look very similar to those (on non CCD trucks).
{tpc}
Anthony
Feb 12, 2022
316
161
Berkley, MI
2022 F-150 302a High SuperCrew 3.5 EB MaxTow
Maybe it’s been mentioned earlier in the thread, but it’s not like the scales give an “exact” number. I suppose you could put measured amounts in there and kinda see where the scale shows, but other than that, it just shows an approximate or shall I say estimated? amount.
Tailight leds are kinda cool, and telling you that your over payload is cool, but that’s about it. I’d venture a guess that most of us worried about going over payload pretty much can already guesstimate where we are at.
Those that fall into the other category, won’t really use it anyway.
DK4
Jan 23, 2022
320
363
USA
Truck
Agreed. I do use mine quite a bit but it’s mostly just for reference and curiosity.
I actually use mine more to dial in my airbags. I pump them up until my scales show where my truck was before it was loaded.
