Installing factory brake controller?
The_Auto_Tech
Cody
Dec 16, 2023
37
477
227
Des Moines, IA
2022 XL 4x2 3.3
Anyone installed the factory trailer brake controller on a vehicle that didn't have it? I found the harness and connector in my glove box that looks like it would go to an aftermarket one, but would rather just use the factory brake controller if possible. Thanks!
Rinn69
Sep 21, 2023
361
514
N Central IOWA
24 F-150 XL 4x4 RCSB Carbonized Gray
Retired USAF Medic
Following.
Popplemer
Stu
Feb 9, 2023
432
405
New Jersey
'87 F250 460 5 Speed, 2023 302A PB 157"
I have done this on my 21 XLT. You need to get the brake squeeze jobber/manual actuator that goes on the dash and theres a module that goes up under the dash on the left side by where your left foot sits. That has 2 multi wire plugs (gray connector and black connector) and replaces a module that's already there. Then you just have to activate it with Forscan. Really easy job.
The_Auto_Tech
Cody
Dec 16, 2023
37
477
227
Des Moines, IA
2022 XL 4x2 3.3
Thanks for that info! One of the guys over on FB said this is the part number that includes the module and switch - ML3Z19H332AB
I'll probably order it tomorrow as I've gotta call out to Ford for a couple other things as well. :)
Popplemer
Stu
Feb 9, 2023
432
405
New Jersey
That's about what I paid. I don't have the part number I used handy but I'm sure that's the same one. As I said it's a super simple job. Just pull off the coin holder and unplug the connector from the coin holder, slap in the dash actuator and replace that module under the left side of the dash. Depending on how cool your dealer is you might be able to get them to activate it so you don't have to mess with Forscan.
The_Auto_Tech
Cody
Dec 16, 2023
37
477
227
Des Moines, IA
2022 XL 4x2 3.3
Very true. I already bought a cable to be able to do the truck and have had FORScan for quite a while now as I also use it for my 13 Flex and 13 Raptor. It's honestly about as easy to use as the scan tool I have for my shop so most of the time I just use it for Ford stuff when it comes in. lol
Popplemer
Stu
Feb 9, 2023
432
405
New Jersey
Oh good I'm glad you're well versed in it. Whenever I boot it up, make my changes and hit write, I can't shake the feeling that the truck will immediately implode like that millionaire tourist submarine last year.
The_Auto_Tech
Cody
Dec 16, 2023
37
477
227
Des Moines, IA
2022 XL 4x2 3.3
For sure. You CAN mess things up, but there's a reason it tells you to save your as-built data as a backup. lol
tony72cutlass's'
Tony
Jul 15, 2021
942
951
Halifax
Following I have the same idea and would like to do this
Would you mind posting a couple pics when you install it?
Rinn69
Sep 21, 2023
361
514
N Central IOWA
Retired USAF Medic
Seems like an easy mod / addition.....I just hope it will work on my '24 XL RCSB when I get it since the TB isn't even an option 🤞🤞
bgalakazam
Lubo
Jun 16, 2021
218
189
Germany
2021 F150 500A Lariat 4x4 5.0L
I installed the -AA version in my 2021 and after Forscan it is recognized and works. The part number is for both the module and the buttons. I had another "controller" box that I swapped with the TBC one near the pedals.
I read somewhere that a TBC is required in certain states to tow past 5,000 (even though my truck is rated 7,000 and came without it). Was an easy swap.
TexasTruck
Scott
Oct 16, 2022
41
771
589
2022 Ford F-150 STX BAP
I fix software bugs!
After I self installed mine, setup ForScan, ForScan/DTC shows an IPC TBC initialization needed something code. I did some research and there is an extra step needed to “teach” the trailer sway hootenanny whatchamacallit you now have a TBC.
I have used mine and it works well, but I wasn’t towing at highway speeds to notice any swaying going on….
Otherwise like those above, the install is easy and if you’re ForScan savvy you’re on your way…. I did check with my dealership about programming it. I kept getting the runaround which made me leery about their ability to not mess something up….
