UGADawg96
I am now leaning towards following the same route and doing it myself. This was a good video to watch although he did make some changes that were detailed in the description and comments after the video was uploaded.I installed myself. On the other side of the wall I put the inlet. Installed 50 amp breaker and connected the transfer switch. Extended 9 circuits from the main breaker to the Generac. It has 8 slots but can accommodate two tandem breakers. Luckily I had 2 breakers that were not arc fault so was able to combine them on the tandem. Basically moved Kitchen, Garage, Family Room, Master Bedroom, and the circuit with the network equipment. Also moved the downstairs furnace to the switch just in case we get another cold snap here in Texas.
The Generac was 339 plus the inlet was 50, generator cable 79, and the romex and breakers needed. Total cost was between 500 and 600.
The transfer switch cuts the hots and neutral so when on generator, it is separate from house neutral preventing a ground fault in the truck.
