IconicXLTsport
- William
- Jun 8, 2021
- 2
- 59
- 68
- North Carolina
- 2021 Ford F150 XLT
- Nuclear Operations
- #61
The FX4 has different shocks so I think it will be different than my truck. If you still find it’s not good, can’t recommend bilsteins enough.Thank you for this review. On my test drive I felt the roll and excessive movement you mentioned and I had made a mental note to address it aftermarket.
I couldn’t test drive a FX4 before ordering and since my order is a FX4 I hope it will be a bit stiffer.
have you considered adding a rear sway bar or do you think that is unnecessary after the four shock upgrades?
right now, the new shocks are so much of an upgrade that I’m very happy with the handling of the truck and I’m holding off on a rear sway bar. Definitely do the shocks first
I’ve never messed with leveling kits but it was my impression that the lift amount was kinda variable anyway. Did they drive the truck and while and remeasure?When you install a spacer that adds 2" inches of height on one setup (Gen13), and then the same piece adds 2.5" of height on the other (Gen 14), That is indicative of a different motion ratio, because you have only changed the spring displacement; you didn't touch the spring rates or suspension components.
I’m gonna look for a deep dive on the 2015-2020 F150
