JExpedition07
James
Feb 14, 2023
50
1,587
2,507
Buffalo NY
2023 F-150 STX 5.0L V8
TFL dropped a new video yesterday. Each truck was impressive in its own right but the F-150 definitely left some to be desired in the downhill braking. Granted no exhaust brakes in a gas engine so not exactly a surprise. Impressed that the 5.0 matched the 6.7 Cummins on wide open throttle acceleration towing that Expedition SUV though, especially at elevation. The Ram does seem to be lifted with bigger wheels though so the Cummins gear ratio is likely effectively reduced vs stock. Either way the Coyote matching the Diesel in that portion was cool to see.
Samson16
Kyle
Mar 24, 2023
2,267
2,129
Orlando, FL.
Aviation systems
My immediate take away is that if not for the range the CyberTruck was far superior to both. Downhill, uphill, merging in, sag, noise level, it was just effortless. Cost per mile was even less with the downhill regen. Cost about $5.20 going up and made about $1.50 coming down.
That lack of range is the Achilles.
The 5.0 showed nicely that even at altitude it can get the job done. Everyday Ike? Maybe choose something else. Towing an RV across the country with varying elevations and grades? Absolutely!
Edit: I'll add that they probably didn't have the CT setup optimized and were just running defaults or it might have performed even better lol.
Samson16
Kyle
Mar 24, 2023
2,267
2,129
Orlando, FL.
Aviation systems
Towing uphill the F-150 used less than 5% of the available fuel while the CT used 17% of its available.
Sports fans know that the most important ability is availability ;)
Polo08816
Aug 11, 2020
418
226
MD
2014 BMW 335i
Range is a huge problem with EVs. They won't be mainstream until they are able to compensate for the lack of pull thru charging stations with significantly longer range. You'd probably need about 400-500 miles of range while towing, or about 1600-2000 miles of range unloaded.
Henfield
Dec 15, 2021
349
274
Usa
2021 XLT Screw 5.0,4x4,302Asport,
Most owners will be using Cruise control on the highway. That would, in tow haul mode shift down to reduce the demand on the brakes.
Did he mention the final drive gear ratio of the Ford?
gagliano7
Joe
Mar 2, 2023
150
77
Monroe NY
2023 F150 4x4 XL STX BAP 5.0 3:73
I have towed with my 5.0 3:73 gears 10 speed. Before I had a 18 GMC 6.2 3:23 gears 8 speed. I am sorry but the 6.2 with its torque tows better than 5.0. I could tell the difference right away.
Henfield
Dec 15, 2021
349
274
Usa
I have towed with my 5.0 3:73 gears 19 speed. Before I had a 18 GMC 6.2 3:23 gears 8 speed. I am sorry but the 6.2 with its torque tows better than 5.0. I could tell the difference right away.
19 speed F150?
Mine has 22 speeds. :)
10 Forward in High range, one reverse. 10 forward in low range and one reverse.
And yes I do use low range.
Walter Townsend
Walter
Aug 27, 2023
112
102
Nelson, BC, Canada
2021 F150 Lariat FX4 Off Road Fishing Edition 5.0
Owner Operator Starlight Tool Services Ltd Millwright/Welder/Machinist/Electronics tech
I briefly considered getting the Lightning, but despite its massive towing capacity, it's range sucked. I could not do the round trip from my place to Trail and back towing our cargo trailer without having to find a place to charge it up. 5.0 Coyote for the win.
Calson
Jul 16, 2022
799
378
Monterey CA
2022 F-150
These guys are clueless about towing. What goes up must come down and with a heavy tow load there is no substitute for having a diesel engine with its exhaust brake going down steep grades.
Samson16
Kyle
Mar 24, 2023
2,267
2,129
Orlando, FL.
Aviation systems
Except the Cybertruck regen was superior. It gained back a full third of the power it used pulling uphill and did so effortlessly. Range is the killer not ability.
Murrk847
May 21, 2023
91
76
BFN, USA
2023 5.0 F150 STX
Yup, My current issues with electric trucks are range under tow. The battery weight to range goes up like a hockey stick. Once they figure out how to make batteries do more with less weight then we will be talking.
Suns_PSD
The Dude
Feb 4, 2023
277
205
CTX
2021 F150 4x4 Limited
Sales
If you tow heavy and often the Cummins makes perfect sense.
But it doesn't make sense to choose a powertrain based on a rare circumstance if you might tow the Ike Gauntlet 2x in your life or something!
The 5.0 is a lot slower at altitude while towing a steep grade, this isn't surprising. What would be weird is buying the Cummins when you don't do that, or something similar, with any regularity.
I will say as someone that used to live in Denver, if you live at altitude, you'll be better served by buying a forced induction motor than a naturally aspirated engine.
