Which 4WP location did your work so when I take mine in for the leveling install and they say the kit will not fit I can refer them to your location?After some back and forth with 4wheel parts, I was able to get my Tremor leveled. A standard kit does fit despite what I was told early on in the process, all the suspension angles remain in spec and it drives the same.
Thanks for the info...Picked mine up 12/3 and this will be the first of many mods to doHe went to the Lake Worth location. I called there and confirmed when leveling my tremor with the same pro comp kit. Works great, no issues so far and ride quality is same.
Damn That's a Beautiful Truck.After some back and forth with 4wheel parts, I was able to get my Tremor leveled. A standard kit does fit despite what I was told early on in the process, all the suspension angles remain in spec and it drives the same.
PERFECT STANCE! I have a 2021 RCSB fx4 that Im going to install rough country leveling struts this week. Tremor package is NICEAfter some back and forth with 4wheel parts, I was able to get my Tremor leveled. A standard kit does fit despite what I was told early on in the process, all the suspension angles remain in spec and it drives the same.
Hi, question about tires. Looks you you are running the 295/70/18 (assuming on the stock Tremor wheels?). Did you consider the 285/75/17 tires? Do you get any rubbing with the 295/70/18 tires? Did you have to cut out anything to make room? Any other thoughts on increasing the tire size while leveling with this pro comp kit?He went to the Lake Worth location. I called there and confirmed when leveling my tremor with the same pro comp kit. Works great, no issues so far and ride quality is same.
A little late, but…… I have the pro comp leveling kit on my 2021 XLT and went with the Falken Widepeaks A/T3’s (285/75/17) on 315 Method wheels.Hi, question about tires. Looks you you are running the 295/70/18 (assuming on the stock Tremor wheels?). Did you consider the 285/75/17 tires? Do you get any rubbing with the 295/70/18 tires? Did you have to cut out anything to make room? Any other thoughts on increasing the tire size while leveling with this pro comp kit?
The front end of the TREMOR looks so much cleaner without air dam hanging down 3 to four inches. Great stance!After some back and forth with 4wheel parts, I was able to get my Tremor leveled. A standard kit does fit despite what I was told early on in the process, all the suspension angles remain in spec and it drives the same.
I leveled my 2022 Tremor but will keep the same wheels and tires for now. Want to see how thetruck preforms and keep the height low. I did a lot of modifications to get it to what I needed but its a great looking truck and rides awesome.
It was a custom fabricated bar. The lights do block the sensors and camera a bit but I have learned to live with it.If you ordered that light bar online, would you mind posting a link to it?
Nice looking truck!After some back and forth with 4wheel parts, I was able to get my Tremor leveled. A standard kit does fit despite what I was told early on in the process, all the suspension angles remain in spec and it drives the same.
