I agree generally, but sometimes the answer to "How come the OEM did it this way?" is "Because it was cheaper and potential buyers either won't care, can be upsold, or won't know until its out of warranty." Replacing parts on a modern vehicle takes a LOT of thought, because almost no part of the truck exists in a vacuum. The suspension is a great example: I am willing to upgrade shocks and wheels, but adding ride height reliably nukes fuel economy for PB owners and hurts handling and towing performance for everyone. Flip side of that is that the skid plates on the FX4 are a bad joke: the engine and t-case plates are thin metal, but the tranny "plate" is a weakly mounted (flimsy angled brackets clipped on to the frame) piece of the fiber board stuff that they have in the front wheel wells. I am suspicious of it in the wheel wells, but as a skid plate it's insulting, and seems to be there so that a buyer who only partially checks (i.e. me) gets duped into beliving that a real skid plate is in place.There have been so many aftermarket parts installed and used on my vehicles, and half the time I realize why Ford designed it with their OEM ways vs the skimpy aftermarket junk, and then revert that portion back to OEM parts.
thanks a lot!!!Sky111, the below diagram applies to your kit.
Unless it is the just released Fox kit for 21-22 F-150s you will need to make this adjustment found here...
https://www.roushperformance.com/media/parts/manuals/1115-5B450IM-AA 9-22-21.pdf
What you did up front isn't causing the sag. The rear sag is what it is.here is what I ordered - it says 2015-2022: https://www.thetrucklot.ca/p-2015-2022-f-150-fox-2-0-suspension-system-422014
Will that 2 inch lift on the front cause sagging at the back when I hook up an RV to tow (600-700lbs tongue weight)
I believe I’m that other owner that complained to them. They told me you have a supercrew, gonna have to adjust it up for that reasonI have a very similar issue to the OP. I have a 22 platinum PB. I have installed the new 21-22 specific Fox 2.0 level and only got 3/4” of lift. I have opened a case with Fox and they are looking into the issue. They did tell me they have another PB case where the guy got 7/8”. So far the response has been … well it is a Plat PB, look at the weight. At this point their engineers are looking at my case and trying to decide if I should add 1/4-3/8 of preload to get my desired ride height or if I should use the prior gen shocks which have stiffer spring rates. I will keep this thread posted. Photo is on a bit of a slope so it does not look terrible but I do have 2 full inches of rake still.
That means you have the gen13 shocks with the stiffer springs. Roush does not use the new softer ones. Fox told me to add preload or swap for those to get more lift. Looks good.I had the Roush package installed on my ‘22 Powerboost w/ Max Tow as I took delivery. Definitely got the full 2”
This does seem to only be an issue on higher trim levels with the Powerboost.This seems to only be related to the Powerboost models. Has anyone else had this experience on a a non Powerboost?
Also, can these be adjusted without removing?
