I got the Ford mat using the Pass points. I found by flipping it over it holds cargo better because of all the dimples on the bottom. You'll have to sacrifice the pretty logo though.Looking to get a bed mat temporarily until I eventually get a spray in liner. Has anyone used both or have another they would recommend?
No, you will need to do some trimming of mat to make fit. More specifically, trimming will need to be done around the wheel wells. I have the OEM drop-in and OEM rubber mat.Does the ford rubber mat fit nicely on top of the ford drop in liner? I was looking at the rough country rubber one that says it does, but I could use points on the ford if it fits well enough on top of the drop in of theirs.
Does the ford mat need the adhesive hook ’n loop system to hold it down or does it just drop in and hold itself down?I did the Rubber OEM Ford mat, it works great. Used Ford Pass points so no charge.
Easy to take out and spray down to clean, objects stay put and don't fly around the bed. Meets all my use cases.
I also have the BakFlip MX4 tonneau covering the bed.
nope. just drop it in place. like others have mentioned its thick and heavy.Does the ford mat need the adhesive hook ’n loop system to hold it down or does it just drop in and hold itself down?
We use those for strongman lifting and competitions. We put those things through some real torture testing and I have literally never seen one get gouged, much less split or fail in any way. I love those things and they are (relatively) cheapi use a 4x6 x 3/4 inch stall mat from tractor supply
its thick enough to take a beating
nope, like @crazywayne311 mentioned it stays down on it's own. It has some decent weight to it plus it is fitted for all the bed contours so it does not move. Heavy enough to stay down but still light enough that you can remove it to clean if needed.Does the ford mat need the adhesive hook ’n loop system to hold it down or does it just drop in and hold itself down?
We have the exact same setup MX4 tonneau and ford bed mat.I did the Rubber OEM Ford mat, it works great. Used Ford Pass points so no charge.
