How to lubricate the standard (non-telescoping) folding mirrors?
RyanStroeder
Nov 1, 2021
39
332
161
Calgary, Alberta, Canada
2021 F-150 Powerboost - Leadfoot
My 21 f150 mirros are folding in and out in a herky-jerky manner. Has anyone ever found a how-to guide to lubricate them appropriately?
Thanks, in advance
VRFlyer
Chase
Dec 10, 2021
598
555
MDW
2023 XLT 3.5EB SCRW FX4
InofoTech
Hahah - speaking of, is she in jail yet? From the memecoin debacle?
Doubt it, but she had posted some long winded apology of sorts to her followers on "X/Tiwtter."
Buyer2021
Feb 9, 2021
44
2,756
4,985
TX
retired!
Silicone spray
If using one of the 'dry-lube' sprays, be ready to promptly wipe-off the unsightly white residue left when the liquid carrier volatizes.
Personally, I found 'no joy' when trying Blaster Dry Lube Spray for this application, just an unsightly white powder mess to clean off of the textured black plastic mirror components.
122
8,502
9,804
2022 307a PB
Still digg'n boys, I'll figure it out
Here's your 'temp sensor' it's the nub on the bottom of the passenger mirror
Ford F-150 How to lubricate the standard (non-telescoping) folding mirrors? 1741306188608-14
Ford F-150 How to lubricate the standard (non-telescoping) folding mirrors? 1741306218121-qa
Unplug mirror motor
Ford F-150 How to lubricate the standard (non-telescoping) folding mirrors? 1741306254079-fm
Knock out pins from other side to remove moving parts frame
Ford F-150 How to lubricate the standard (non-telescoping) folding mirrors? 1741306311388-u5
About to remove the motor's assembly and see what up
Ford F-150 How to lubricate the standard (non-telescoping) folding mirrors? 1741306355616-k6
The housing is sonically welded. Tried to remove the metal from the inside, broke a razorblade trying to separate, on the verge of destructive disassembly so I paused. About the only thing you can do is lube up this area right here. The motor assembly leaks what appears to be white lithium and there's no way to put any back in sans drilling a hole into the housing somewhere.
Ford F-150 How to lubricate the standard (non-telescoping) folding mirrors? 1741307868971-e7
The motors are made by these guys FWIW
https://www.motioncontrols.com/products/power-fold-280
122
8,502
9,804
2022 307a PB
Davexxxx
Mar 25, 2023
69
1,276
1,359
MO
Boeshield T9 comes in a liquid and a spray.
I haven't used it on plastic yet but the manufacturer says it is safe for it.
It does not turn white.
RyanStroeder
RyanStroeder
Nov 1, 2021
39
332
161
Unplug mirror motor
dude you are amazing
how do i get that deep though? I just want smooth motion instead of herky jerky when it opens and closes...
122
8,502
9,804
2022 307a PB
I suspect it's a worm drive just like the shifter. When the mirror is folding in, inspect the lower portion still on the truck and you should see the rubber that I outlined above. You can try a lubricant on the rubber itself as shown here. This area should be obvious when folded.
Ford F-150 How to lubricate the standard (non-telescoping) folding mirrors? 1741315626362-75
122
8,502
9,804
2022 307a PB
Eh, I'd be careful what you use. It's just rubber, and will end up on the truck eventually. Not sure if it will really do much in the long run.
