How to find latest version of OTA SYNC4 Updates?
johnatuckeriii
John
May 16, 2021
68
54
Houston
2021 F-150 FX4 SuperCrew AMB
It’s also possible you had this issue due to a poor internet connection. I was updating the TCU in the wife’s Escape and the first time it jumped to from about the 60 percent mark to complete… then the module didn’t come back. Had to start over and noticed I couldn’t log in and couldn’t verify the vin. Once I relocated to a better position all was better.
heffer86
Sep 3, 2020
152
85
Iowa
2021 F150 Lariat 501A
When it says “restart the truck”, you need to shut it down completely. That means, ignition off, open and close drivers door. Then wait 10 minutes (this is the important step)!!
let me know how it goes
Ok, I hot the APIM to update after the third try. I am now on 21146 Rev 145.
I tried to update he IMPA and I can't get it started I got a these messages both times I tried. "Reprogramming Failed" (Click "no" the second time) and then got the "Security access failure". Thoughts?
Ford F-150 How to find latest version of OTA SYNC4 Updates? 1642285481992
Ford F-150 How to find latest version of OTA SYNC4 Updates? 1642284926179
I moved on to the Gateway module. I am currently in the reboot message loop. I have waited the 10min opened the closed driver door. Do you need to start the vehicle or just cycle the ignition after 10min. Done both, no luck.
iceman77
Pete
Dec 29, 2021
453
532
2022 Ford F-150 Platinum
Not sure about IPMA.I have flashed it without any issues. It just takes forever. About 3 hours or so.
For GWM, it should be the same procedure as APIM. Ignition OFF. Open driver door and close. DO NOT REMOVE THE FLASHDRIVE. Wait 10 minutes. Ignition ON. Wait couple of minutes until SYNC screen informs you that update was successfull. Remove the flash drive
Ruffiano99
Joe
Jan 11, 2022
107
28
NY
2021 f150
How many amp tender/charger is recommended for this to run the updates?
9,035
16,332
A few of us are Powerboost trucks. I still put a charger on it but it takes a lot longer to drain the 12V system on it. I'm not sure I really needed it.
Ruffiano99
Joe
Jan 11, 2022
107
28
NY
2021 f150
Thanks. I should have mentioned I have the powerboost too.
Ebrou
Jul 8, 2021
101
51
Mobile, AL
2021 F150 XLT SCREW 5.0L Sport 4x4
This in in TSB 21-2310 concerning the SYNC 4 for updating for other issues. This might be the reason you're getting the error messages.
NOTE: The gateway module (GWM) must be at the latest software level before the APIM update
can be performed.
9,035
16,332
can be performed.
I knew this and intended to update the GWM first, but FRDS didn't make a GWM update available until after I updated the APIM and TCU.
I was still happy when I finally saw it populate!
