m_bt54
- Bryan
- Nov 16, 2022
- 7
- 554
- 618
- Massachusetts
- 2021 F150 Lariat Powerboost Hybrid
- IT Director
Not looking to argue about if anyone should/shouldn’t do this or if it meets code where anyone is. Just sharing what I did, I have no qualifications to suggest anyone do the same. A licensed electrician did assist me with this install.
What I used
10/3 wire -https://www.homedepot.com/p/Southwire-50-ft-10-3-Solid-Romex-SIMpull-CU-NM-B-W-G-Wire-63948422/202316239
1-2 ft 10/3 rubber power cord (for adapter to remove ground)
L14-30 plug set - https://www.amazon.com/dp/B074KH4T7T?ref=ppx_pop_mob_ap_share
Interlock kit (I have a Murray panel) - ACANORA Generator Interlock Kit for Murray or Siemens 150 and 200 Amp Panels, 7/8 to 1 1/4 Inches Spacing, Brushed Nickel https://a.co/d/ccmb6AX
2 pole 30 amp breaker (depending on panel)
30-Amp-Space Generator Power Inlet Box - https://www.lowes.com/pd/Reliance-30-Amp-Generator-Power-Inlet-Box/3133095
Generator extension cord- https://www.lowes.com/pd/Utilitech-Pro-Generator-Cord-Generator-Cord/3191751
I also used one of these cut in half and discarded the end piece to get a watertight conduit from the inlet box into my basement, but there are probably cheaper ways to do this - 3/4-in Schedule 40 Schedule 80 Plastic Elbow Conduit Fittings https://www.lowes.com/pd/Kraloy-3-4-in-PVC-Flexible-Elbow/5001212873
You will also obviously need appropriate wire staples, caulk (which I still need to go back and do!) and a clamp for where your wire enters your panel. I also used a siding block that I need to replace with one that is the appropriate size.
What I did
1. I ran the 10/3 wire in my basement from my panel to as close to my driveway as I could get it with a few feet to spare on each side and stapled it down. I didn’t want to have to drive into my yard to hook it up during bad weather or I could have done this with 10ft of wire instead of 50ft. I also didn’t want to buy 100ft of cable to get the extra ~8ft I needed for the perfect spot.
2. Drilled hole through the side of my house and installed the inlet box. I used the 1/2 piece flexible elbow listed above to make it watertight.
(I’ll be remounting this to make it look better this weekend!)
(I’ll be caulking this this weekend and adding a few more staples as well!)
3. Connected up the wire to the inlet box and my panel. I decided to include the ground in the event I want to use this with a different generator in the future.
4. Installed the generator interlock kit
5. Made a 1ft extension cord with the ground removed using the rubber cable and L14-30 plug set ( I also didn’t want to remove the ground from the extension cord)
I shut off my main breaker, connected it all up with the extension cord, started my truck and tested it out for a few hours and it worked as expected. My biggest surprise was how low the load was during the test.
What I used
What I did
