Highest Supercharged Mileage
JExpedition07
James
Feb 14, 2023
58
1,891
3,197
Buffalo NY
2023 F-150 STX 5.0L V8
Does the Raptor R have a specific catalytic converter? That’s 720 HP and I’ve not read of one engine or catalyst issue.
fecalflinger
Jeremy
Oct 25, 2023
37
66
Tennessee
2023 F150
Oh I could pull the plugs and check the gap. I could also install headers and aftermarket cats myself, but I have a 3/36 Ford warranty and a 3/36 Roush warranty that should take care of it. My biggest issue is that my local dealerships aren't willing to work on it. I am currently waiting on the dealership I purchased the truck from to get a new Y pipe with cats in so I can drive 4 hours to let them swap it out. The problem is that they are on back order and wont be in for 2 weeks. Probably because everyone is needing to replace their cats. My other fear is that I drive 4 hours to have them put on the new cats and I still have the problem. I have a feeling I am going to have to leave my truck with them for several weeks and not have a vehicle.
Davidwnuc
Mar 13, 2022
433
392
Mississippi
On order ‘22 RCSB.
Slyder
Dec 20, 2023
PNW
2023 Bronco, KTM 1290R
I got a reply back from SPD on the cats they offer on their down-pipes and it's something to think about if you ever need to go a similar route.
They said the standard cats are ceramic core and good for about 800rwhp (roughly 400whp per bank/cat) and their optional GESI cats are stainless steel core and good for well over 800rwhp.
I'm likely to go this route but an exhaust set up for the RCSB will end up being a true dual exhaust that will need a bit of custom work done to make it work on it. They offered to help with that if I needed it.
TexasTruck
Scott
Oct 16, 2022
41
770
589
2022 Ford F-150 STX BAP
I fix software bugs!
Intake air temp is another factor in the puzzle.
Sensor 2 is post cat
I added 1 and 2 in OBD Fusion. At first the values were the same. As I drove around sensor 2 was a few degrees cooler. I guess that’s because the CAT absorbs some of the heat.
jorligan
Tim
Dec 15, 2022
2021 F150 Platinum Paxpower conversion
52000 miles 2021 Platinum. Whipple 3.0 installed and tuned by Livernois. Occasional spirited driving and towing of 26 foot covered aluminum trailer with 3200 lb car. 6300 total weight towed at 75 mph. Borla S-Type cat back exhaust. Running 35 with a Raptor body conversion using OEM Ford parts. We call it the Fraptor.
TexasTruck
Scott
Oct 16, 2022
41
770
589
I was mistaken… there isn’t a 2nd sensor. Just sensor 1 bank 1 and sensor 1 bank 2.
TheGoatman
May 30, 2021
753
472
Powerboost
22 powerboost
don’t have a 5.0 in this truck so not sure but I’ve never seen a cat without a sensor before and after it
TexasTruck
Scott
Oct 16, 2022
41
770
589
I didn't mean to imply there isn't one :) It could be another PID name or even a bug in OBD Fusion 🤷‍♂️
TexasTruck
Scott
Oct 16, 2022
41
770
589
Another thing I noticed is the Intake Air Temperature (IAT). It's been in the 70's here and according to OBD Fusion my IAT readings are 90+*.
Is that normal, what's going to happen when it's 100*?
Where is the IAT sensor?
2whiny
2whiny
Jan 1, 2023
Fort Worth, TX
2022 Ford F-150, 2001 Ford SVT F-150 Lightning
I don’t think there are physical temperature sensors for the cats. Based on what I’ve read, it’s calculated based on an algorithm that’s apparently accurate on stock vehicles. Who knows how the Roush, Whipple or FP tune would affect that.
I use a Banks iDash to monitor the virtual cat temps and they quickly go above 1600 degrees, the point at which COT would start working. This happens on WOT pulls longer than about 3-4 seconds. I’ve read elsewhere that complete meltdown wont occur until 1900+, but I assume sustained temps of 1600+ aren’t awesome. I have an alarm set for 1700 or 1725, I can’t remember, to let me know I need to get out of it. I also have an alarm set for 12+ PSI of boost.
Seems like the guys on the FB pages that lose motors go through the same scenario:
They get a P0430 and then a P0300, figure it’s plugs or an anomaly, swap the plugs and/or clear the code and they keep driving. The cats are already damaged at this point and causes a runaway effect. Blocked exhaust >> high pressures/piston damage >> more misfires >> further cat damage
The moment I see a P0430 or P0300 code, AAA is getting called and my truck will be on a flatbed headed to the dealer. Seems like guys that catch it before the P0430/P0300 show up together end up being okay.
TexasTruck
Scott
Oct 16, 2022
41
770
589
Is that a virtual value too? I’m not sure what PID I should monitor or figure out how to calculate in OBD Fusion. Is boost built in to iDash?
Thanks.
2whiny
2whiny
Jan 1, 2023
Fort Worth, TX
Thanks.
The Whipple kits add a MAP sensor, so it’s a real value. I was able to just add the PSI/inHG in the iDash. No calculations or anything. Not sure how it works with OBD Fusion.
TexasTruck
Scott
Oct 16, 2022
41
770
589
In their app you add PIDs (not sure what that stands for) to a page. In this case I add the Manifold Absolute Pressure sensor like so:
Ford F-150 Highest Supercharged Mileage 1708710627636
When the app is connected to the truck, I see it range from 7 to 25 psi when I'm driving normal like. That seems a high to me. 🤷‍♂️
