bgalakazam
After a lot of struggle and broken plastic tabs, heated steering wheel is in and works! Day and night difference.
Pretty sure he doesn't have adaptive steering. They won't let you order that on any 2023 F150, unless something has changed very recently. Doesn't matter what trim you bought in early '23 - Ford deleted the heated steering wheel for you.
IF you use the appropriate gauge wire it should be ok to use speaker wire. Also, make sure it's really copper and not copper clad aluminum which is common now in speaker wiring.![]()
It’s solid. Will this not work then? Should I just use speaker wire then?
I spoke with a guy at Ford parts and he confirmed to me that the ML3Z-3F791-BB is not suitable for Raptors. I gave him a 2022 Raptor VIN that came originally with heated steering wheel and he informed the PN is ML3Z-3F791-HB. I will place an order today and hopefully will get it done. I will keep you all updated.
I wondered. Pop the airbag off and see what your working with, if you have the right wheel that's a plus, but still not great news as the right parts ain't cheap with adaptive steering. You really get shafted with the heated wheel delete on trucks with adaptive steering, as credit of $140 isn't going to be very little help if you try to add it back.Well, the sticker says my Limited has adaptive steering so ...
I wish I could just pop the airbag off like the rest of you but there are no little tabs to push on the back of my steering wheel.I wondered. Pop the airbag off and see what your working with, if you have the right wheel that's a plus, but still not great news as the right parts ain't cheap with adaptive steering. You really get shafted with the heated wheel delete on trucks with adaptive steering, as credit of $140 isn't going to be very little help if you try to add it back.
Looks like the Limited wheel is different.I wish I could just pop the airbag off like the rest of you but there are no little tabs to push on the back of my steering wheel.
That's at the "bottom" of the wheel when it is "straight" so I don't think that's it.Pretty sure its in this hole
What year is your truck?That's at the "bottom" of the wheel when it is "straight" so I don't think that's it.
It's a 2023 Limited so it has the adaptive steering. Apparently a whole different animal when it comes to the steering wheel and associated parts.What year is your truck?
And the pics that @JScaro posted dont look like a 21+ wheel since the bottom is closed. Everything about this is confusing right now.
OK got it, see attached.It's a 2023 Limited so it has the adaptive steering. Apparently a whole different animal when it comes to the steering wheel and associated parts.
Ahhhhh - I noticed what looked like springs in the ebay photos (there are 4 2021+ limited wheels on ebay right now) but couldn't figure how you would get to them. Tiny holes on the side. I would never have found those on my own.OK got it, see attached.
