MikeA
Yeah, I understood how it works. I was just agreeing with what you said about having a PB and not opting for the 7.4 kw. 7.4 is a no brainer if you are already going PBIt will put up to 7.55 kW. The difference in the PB's PPOB vs the non hybrid unit is that it can power from the battery alone. There's 800Wh of energy that can be used from the battery before the engine starts, and if the load is below ~1.6kW, the truck runs in hybrid mode vs the standard F150 and 250's PPOB requiring full-time engine running.
For instance running a refer and a freezer, the PB would end up using 1/10th of the gas, or less vs the other PPOB systems. Both the 2.4 and 7.4kW powerboost PPOB work in this manner. Personally I don't think it was even worth offering a 2.4kW unit w/ it. The PPOB trimmed lightnings have both of the PB's inverter options. The 2.4kW in the frunk / cab, and the bed option with the 7.4kw as well offering a combined output of 9.6kW worth of power to tap.
This is independent of the home backup option that allows the lightning to feed its HVB to a separately purchased inverter that stays in the home. This is why the connector used for the charge station pro utilizes the DCFC pins whereas all other home charging uses that stand J1772
Charge station pro w/ HV home back feed
VS all other AC home chargers with J1772
And was also glad there was a 2kw option for non PB because I really did not want the Hybrid
