5.0L V8 Front diff fluid change, is friction modifier needed?
TJSparky
Oct 18, 2021
501
439
WA
I know on the rear diff, with electronic locking, friction modified is not required but what about the front? Is it required in the front with the 75w85 hypoid gear oil?
Pedaldude
1,371
1,992
It should say it in the owners manual. Which it probably doesn’t.
I don’t think that either this generation, or even the last was available with a clutch pack LSD.
The Torsen front differential doesn’t require added friction modifier to work but some OEMs use it and even Torsen recommend using a couple ounces for a particularly noisy diff but just to quiet it up.
Open differentials don’t use friction modifiers.
The only trucks that it would make sense to have a multi plate clutch LSD would be those with 4A transaxles because it wouldn’t make much sense off-road and since Torsen work okay off-road and pretty well for pavement and gravel, they’ve pretty much replaced the old school clutch pack limited slip differentials in many applications for several reasons.
Good luck!
TJSparky
TJSparky
Oct 18, 2021
501
439
WA
Looks like it does require it for the front. Below is the info out of the 2021 Service Manual.
2021 F150 XLT FX4 5.0L
My truck is a Rocky Ridge with a 6" lif so I have plenty of room to get to the front diff compared to normal trucks.
Ford F-150 Front diff fluid change, is friction modifier needed? 1677981775433
Ford F-150 Front diff fluid change, is friction modifier needed? 1677981822049
Tomatoboy
Apr 3, 2022
295
239
Maryland
2018 Ford Explorer XLT, 2017 Ford Escape SE, F-150
If I’m reading that right, ONLY those with the Torsen need the friction modifier.
9,040
16,377
Only if you have the Torsen though, right
Edit: Sorry for the echo. Hit submit 5 seconds later. :)
TJSparky
TJSparky
Oct 18, 2021
501
439
WA
Again this is for the front Differential axle.
I think all ‘21 f-150’s 4x4’s have this or was it an option?
9,040
16,377
No. Actually very few F150's have front differentials with any kind of limited slip.
Only the Tremor and Raptor, to be precise.
Unless I have lost my mind. :)
Edit: But I wish mine did!
TJSparky
TJSparky
Oct 18, 2021
501
439
WA
So your's has the Torsen too?
9,040
16,377
I have a 2022 KingRanch Powerboost 4WD.
So I would have the 4A transfer case, but the same front diff as every non-Raptor (or Tremor) that Ford has been using in the F150 for a decade.
No Torsen
No clutch of any kind
No limited slip
An open differential
You can add a friction modifier if you are hell bent. 😁
But I don't see how it would help or hurt because there's nothing in the differential that it would apply to either way.
Big Dog Daddy
May 27, 2021
1,685
2,460
New Jersey
The only trucks that are factory equipped with a Torsen front differential are Raptors. All other F-150's are equipped with an open differential. So if you're truck is an XLT it uses the lubricant as listed below.
205-03 Front Drive Axle/Differential 2021 F-150 Specifications Procedure revision date: 06/11/2021 Specifications Capacities Item Types of Axle Liters Material : Motorcraft® SAE 75W-85 Premium Synthetic Hypoid Gear Lubricant / XY-75W85-QL (WSS-M2C942-A) Conventional 1.83 qt ( 1.73 L) Material : Motorcraft® Ultra Silicone Sealant / TA-29 (WSSM4G323-A8) - -
Grafx36510
Rob
Apr 18, 2022
827
932
NY
2019 F150 XLT 302A/2022 F150 Tremor 402A
The guy that everyone b*&%ches to at work...
As a tremor owner who paid for the Torsen, it’s not just raptor owners with a front Torsen diff.
