Not the issue some are having me included. Just had a 6 hour trip after stopping for gas and lunch on a hot sunny day with no moisture anywhere to be found, we got to listen to our warning beep every 10 seconds for the next 4 straights hours and to top it off when this happens we lose cruise control.I get that message in the mornings when moisture is on the windshield.
It self clears and it is fine the rest of the day
Did they replace your body control module? They are replacing my IPMA module tomorrow morning. I'll let you know how it goes.@smartin2232
Mine is in the shop right and apparently Ford (i have case open too) is using mine as a guinea pig because they don't know what is causing it.
They replaced the control module but that didn't fix it. Ford is having them run a bunch of test and a whole slew of different errors keep popping up.
One thing I told the dealership which has helped them is if the truck sits in the sun the error will come on 100% of the time so they can easily replicate it when Ford wants them to run another test.
Sounds like the next step is replacing the camera but that still doesn't answer all the other errors they are seeing when running the test.
I will keep you posted if they fix it.
They did but that didn't fix it. Ford had them run a bunch if test because they can replicate it pretty easy by letting it sit in the sun for 30 min or so.Did they replace your body control module? They are replacing my IPMA module tomorrow morning. I'll let you know how it goes.
Instead of replacing the IPMA, I got the run around againDid they replace your body control module? They are replacing my IPMA module tomorrow morning. I'll let you know how it goes.
Its ridiculous how poor Ford service is. I don't have a lift and get the issue, its obviously not the lift.Instead of replacing the IPMA, I got the run around again
Well Ford is still trying to work on my issue. Currently my Pre-collision alert NEVER turns off, it used to only happen when the Truck sat in the sun but since they replaced the control board its completely broken. Now that the pre-collision never turns off I don't have adaptive cruise, regular cruise, lane departure or any safety features.It is so finicky and bizarre.
I have started the buy back with a lawyer but they think I would probably get more on trade right now due to the shortage of late model trucks.... OMG I am soo tired of Ford right now.
Yeah I figured.These guys are desperate to sell cars and make money so best to try and sell it yourself if you go that route.
