Hey there... I’ve done a couple of changes to my f150 via forscan and I’m just south of the woodlands. I would say forscan isn’t fully baked yet for our trucks but what were you wanting to do?
I can tell you removing the belt minder chimes doesn’t work yet (at least I haven’t been able to disable them). I have been able to kill the double honk.
This is from another thread for seat belt chime. It works.
For those who can safely do away with both the icon on the dash and the warning beep, here's the process: (you must do every step, INCLUDING the emergency brake upon exit):
1) Set the emergency brake
2) Exit the truck
3) Wait a minute (my ad hoc recommendation)
4) Get in the truck, sitting on whatever seat you wish to disable the seatbelt nanny (maybe you have FIDO as a ridealong in the back seat) - do NOT touch any pedals
5) Press the start button (again without a foot on the brake pedal) to activate the ignition, or turn the key to on if you have an old style starter
6) Watch for the seat belt icon to go off. This will take up to one minute, but it will eventually turn off
7) When the seat belt icon turns off, insert the seat belt latch into the receiver three times in a row, ending with the seat belt unlatched. The seat belt icon should come on again.
8) Insert and remove the seat belt latch one more time. The seat belt icon will flash three times and go off permanently. No more seatbelt warning for that seat. Repeat for any other seats where you want the warning deactivated.
