Paul Neubauer
Nice find! Appreciate it!take a look at this post for your requested running board mod - worked for me.
https://www.f150gen14.com/forum/threads/ecu-module-programming-guide-using-fdrs.8249/post-194452
I believe that doesn't turn the fog lights off when you turn on your high beamsWhat's Bambi mode?
Fogs and high beams simultaneouslyWhat's Bambi mode?
FORScan is used to change your “as-builts” which basically just flips a switch in the existing programming to make your truck perform differently.What's the difference between FORScan and FDRS?
I don’t recall what the acronym is but they’re basically error codes in your modules. A DTC is to a module what a CEL code is to the vehicleDTC's?
Before anyone asks, last I checked, this is only available for Lariat and above full digital dashes.... right guys? Wish I could add this to my 302A...Digital gauge readout. I like this for the coolant, not so much for the transmission. Why this setting isn't OEM is beyond me.
I haven't read of this. What is this?Added sided screens on Powerboost screen
Question what is the "unreal engine" and whats the code for brighter DRL?Bambi Mode
Digitalgauges
Global Windows
Silent mode
Glare free lighting
Brighter front marker lights
Bed/hitch camera
Unreal engine
75th anniversary screen
90% battery charge
On the PowerBoost trucks, several of the side cards are missing. This adds them back:I haven't read of this. What is this?
