Catastrofe
Great job on this widget…thank you.
What’s wrong with this picture? I’m surprised no one else has caught this.
You dont have the “Left Front” and “Left Right” or the “Rear Front “ and “Rear Right” OEM tire package?Great job on this widget…thank you.
You might be out of date. Same with tire guy. I'm on 03.14.0Hi Tonesto-
Is there a problem with the newer script 2022.03.10.2? My module data won't come up. If I try to do a "get data" it comes back with...
Errors Logged
save.JsonFile Error: Error:
"MYVIN#.json" couldn't be removed
I have 2 of those tooMy Module data shows 2 “Unknown Module”s, one is BECM and one is SOBDMC. Is that normal
I am, still undefined. Is it the widget that makes it undefined or vehicle/ford/FordPass?I added more modules in the most recent update.
Make sure your running the latest
That happened to me too, but I think it was because there was an update in progress or maybe a problem at Ford’s end. The Ford site gave me even less information than normal while that error message was up, but an update since came through and the widget is working again.Not sure when this stopped working, but with 2022.03.27.0 I can no longer see the OTA Update Info page:
This used to work.
Thanks!
I think you’re right - mine is now working as well, and it no longer shows the upgrade failure it had been reportingThat happened to me too, but I think it was because there was an update in progress or maybe a problem at Ford’s end. The Ford site gave me even less information than normal while that error message was up, but an update since came through and the widget is working again.
Mine has been like that for weeks.Not sure when this stopped working, but with 2022.03.27.0 I can no longer see the OTA Update Info page:
This used to work.
Thanks!
This used to work.
Thanks!
Yeah, that data is 100% on Ford's side.I think you’re right - mine is now working as well, and it no longer shows the upgrade failure it had been reporting
