BoilerTimmay
Tim
Sep 20, 2020
542
298
Indiana
2011 SCREW 3.5L
Are there benefits to the sensor over the sticker on a conventional trailer?
Advertisement
BMWtoF150
Marty
Jan 7, 2021
98
92
SC
2021 F150 King Ranch, 3.5 Eco
Retired, Part Time Consultant
There are a couple i see.
1. You don't have to make any measurements
2. I used to have the sticker go out of sight (backing down incline) and the assist would alarm and shut off.
Camptruck
Linus
Jan 10, 2021
28
Canada - Ontario
2017 Volt, 2021 F-150 (on order)
Project Manager
See the screenshot from my chat with Ford Support. "There will be an update coming..." It's odd they released this truck and removed the sticker option that worked so well with my 2016 XLT.
Re " There will be an update coming..." It's odd they released this truck and removed the sticker option that worked so well with my 2016 XLT. "
If they built SYNC4 from the scratch, rather tan starting with SYNC3, it would be a matter of not having added it to SYNC4 yet. With over the air updates it gives Ford the option of developing the minimum needed to release the truck & add less important features later.
DFlynn68
Jan 13, 2021
29
Charleston SC
2021 F150 Lariat FX4
Agriculture
Good news on the Sensor front. After watching the video I went out and connected the sensor to my 27' EZ Loader boat trailer. Confirmed that the sensor with wire harness does in fact work with a conventional trailer. Once I connected everything up I went through the calibration process. You do need room to make some sharp turns. It had me do several turns then let me know the calibration was good. I backed into some very tight spots with ease. Great feature but I will be glad once the sticker config update is ready. See pics of my set up. Only thing I need to confirm now is whether the spot I put the sensor will be submerged at the boat ramp. Will verify and adjust as necessary.
jerryllah
Jerry
Feb 6, 2021
Kerrville Texas
2021 F150 Platinum 4x4 Powerboost
After watching the video from the link on previous page it says after you calibrate the sensor that it saves all the trailer info from the calibration to the system and you can add up to 10 trailers. do you think the sensor can be removed and used to calibrate another trailer. The point the previous post brought up if the sensor is on a boat trailer it could be under water at some boat ramps. That sensor kit is $354 from ford parts. How could ford expect us to buy a sensor for every trailer.
BoilerTimmay
Tim
Sep 20, 2020
542
298
Indiana
2011 SCREW 3.5L
In theory it has to be water proof, right?
DFlynn68
Jan 13, 2021
29
Charleston SC
Agriculture
It looks like it will be protected from rain and splashes. But if you look at the right side of the sensor it’s pretty wide open and the connector doesn’t appear to be IP67. I’m not confident submerging it.
daemonic3
Terry
Sep 22, 2020
958
660
Sacramento, CA
2017 F150 3.5EB
Man...
I'm confident that it works great. I just don't like having to secure extra wires like that, and look at that length! It definitely is primarily designed for 5er/gooseneck trailer, where it will be somewhere near the kingpin inside the bed, and have more length to go out, over the tailgate, and to the connector. A conventional trailer does not need that much length for sure.
Also look at how on the conventional trailer the wiring has to do that initial sharp 180 degree turn, as the natural side you want to put it on is the SAME side as the truck's plugs. If it is attached inside the bed, the cable has no initial 180 degree switchback.
Regarding multiple trailers, imagine having to remove and secure it every time with zip ties. That is incredibly annoying. I'll probably use velcro straps that are re-usable instead.
jerryllah
Jerry
Feb 6, 2021
Kerrville Texas
I would like for you to hook the trailer and not plug in the sensor and see if back up assist works. That would be the answer we all need to hear.
DFlynn68
Jan 13, 2021
29
Charleston SC
Agriculture
You have to have the sensor plugged in / connected for the system to activate. That said, even If you don't have the sensor connected, the back up camera still works great and has a wide angle view when using the trailer mode. It helps you see areas that your mirrors cant. I did not have this enhanced camera view on my 2016 XLT. It's very helpful backing up on your own manually.
chrisp993
Sep 21, 2020
64
44
Bloomfield Hills, Michigan
2016 F150 Lariat, 2015 Audi S4, Spec Iron Mustang
My plan is to attach to my trailer using 3M Dual Lock available from Amazon, Home Depot etc. this stuff works like velcro but interlocks using hard plastic "mushrooms" and is incredibly strong but you *can* attach/detach if needed. Could place a "base" of one half of the tape on each trailer and move the sensor from trailer to trailer as needed (y) or remove from the trailer to avoid leaving the sensor in open-air storage etc.
jerryllah
Jerry
Feb 6, 2021
Kerrville Texas
I installed the sensor on one of my trailers today. Installed with zip ties. Impressed with the way it works. Ordered a second sensor for the other trailer I use most often. I'll wait for the stickers for my other trailers. With zip ties the sensor can be moved to another trailer very easily.
daemonic3
Terry
Sep 22, 2020
958
660
Sacramento, CA
2017 F150 3.5EB
I'll probably be doing something like this, plus velcro straps. The extra issue (I realize this is probably just a me thing) is that I don't leave anything valuable unsecured in my hitch area when I put it in storage, including my battery. So I will be removing the sensor to store inside my trailer every time.
For occasions using my utility trailer, I think just the reverse cameras are gonna be a HUGE benefit and I can live without the pro backup. It was always difficult when the trailer was empty as I cannot see it well (low to the ground). The tow mirrors and 360 camera will give some pretty amazing visibility now until they give me a sticker update.
DollarBills
Jason
Feb 9, 2021
Kennewick
2021 F-150 XLT FX4
Security
Sensor installation was super simple. I installed it on the tongue of my travel trailer. Clean off the spot peel off the back, make sure arrows are pointing up then press on. Plug harness in to sensor plug harness in to truck. Make sure you are on flat and level ground and have room to turn right or left. After you are plugged in you simply drive forward and then turn left or right for calibration. Done works like a champ.
TommyGun
Tommy
Aug 14, 2020
St. George, Louisiana
2021 F-150 XLT & 2013 Ford Escape
Environmental Scientist
Just got this recall notice. I wonder if this is linked to the Backup assist decal targeting?
Advertisement
Advertisement
