Ford OEM power running boards install a plug-n-play?
superfordman
Troy
Jun 29, 2021
813
779
NE CO
2023 F150 Lariat 501A
Precision Ag Guru
I got mine installed last weekend and I love them so much it’s a tie with the cooled seat and stereo upgrade. The super duty’s are a little low when you look at it, but the perfect height for getting in and out. The harnesses were not too bad to make. I had about 6 hours in the wiring and testing and maybe an hour putting the boards on when I had it on the hoist for oil change. I did have to reverse the wires as mentioned previously because they went the wrong way. I love having control so I can leave them in or out when needed. I highly recommend this upgrade.
Looks great! Yes they do go a good amount lower and take some getting use to. Pretty much any power boards will work on any gen of truck, 2015+ of course, they all use the same connector and you may just need to reverse the motor wires like you found.
Stefanolimotta
stefano
Apr 14, 2022
75
21 f150
Construction
Yes.> its a big job. Its not easy.
You need new harness for the seat. Then you need to run the wirng from the seat module to the Running boards. you need a new DSM You need ot have the DSM programmed.
I added them Ive done it.
Pus you have to make all the as build changes.
The harness that are needed did you get from ford or are these some thing that have to be made. I would like to add these on my 22 xlt 302.
Wilbur444
Rich
Feb 17, 2024
AZ
2023 F-150 Powerboost
Still looking to remove mine from my 2023 Powerboost Lariat.
If anyone is interested send me a PM
JJSnell
JJSnell
Feb 22, 2023
62
1,330
1,621
CdA, ID
2022 F150 Platinum FX4 PB
Stefanolimotta
stefano
Apr 14, 2022
75
21 f150
Construction
Yep, pretty much, if not more for everything, been a while since I've even looked though
That is steep I’m pretty interested though. I’m trying trying to figure out where I get these harness if they need to be make custom or if there’s a pet number for it
Iceman2022
Jake
Nov 7, 2022
60
33
2022 F150
Controls Engineer
I paid $600 for new Super duty take offs. If you start on page one and read the thread completely you will find most the information you need to complete this project.
ReverendQ
Kevin
Mar 26, 2023
198
214
SoCal
Website
www.linkedin.com
I am thinking about tackling this for my next modifications to MTY23 302A BAP SCrew that includes a powered driver seat, however not cooled, but no DSM. Can you verify what I need is:
a) EDIT: Per #100 @superfordman, I ordered Take Off 2017-2023 Ford F250 F350 Super Duty Crew Cab OEM Power Running Boards | eBay $618
b) EDIT: Per #100 @superfordman , I ordered MU5Z14C708G from Ford $258
c) @Jesse-Infotainment any update or ETA on the plug-n-play kit for the XLT?
d) @superfordman once I add the DSM, just your spreadsheet programming in ForScan? EDIT: I am guessing adding a new module is a bit more than the spreadsheet?
e) @Iceman2022, @HammaMan Am I missing anything?
TIA
superfordman
Troy
Jun 29, 2021
813
779
NE CO
Precision Ag Guru
a) @superfordman would these boards work? Take Off 2017-2023 Ford F250 F350 Super Duty Crew Cab OEM Power Running Boards | eBay
b) and is this the correct DSM? 2021 FORD F-150 FRONT POWER SEAT COMPUTER CONTROL MODULE UNIT OEM MU5T-14C708-BG | eBay . BTW, where does it mount to the truck, under seat?
TIA
a) Yep those will work great
b) No, that is a low spec DSM, you need to get a MU5Z14C708G
d) Yep pretty much, programming is the easy part once you have it wired in
ReverendQ
Kevin
Mar 26, 2023
198
214
SoCal
Website
www.linkedin.com
Success!!! Finally got everything installed, working like it should, and wrapped up (literally) last night! Not having both boards connected must have been my first fault, as when running the DSM self test, they go through quite the dance back and forth a number of times before it completes. After that was done, they worked just like they should with zero issues. I wrapped the chrome strip with some black wrap, which to my suprise turned out really good so will see how that holds up. I cleaned up my seat harness and then snaked the passenger harness up through the footwell then down the left side of the center console to the bottom of the seat which worked great. I was going to try and add the kick switch, but no use really since they don't extend back to the bed at all, so little need for a switch when I could just open a door.
The biggest thing to note is since I used super duty steps, they do come down lower so it is a different feeling now getting in, so will take some getting use to. These steps would work great for someone with a 3"+ lift and bigger tires for sure, but with my just leveling kit and 34"s, they are definitely lower than I'm use to right now.
I would be curious if someone with the normal OEM steps could measure where the step is when out in relation to the door sill trim plate, as curious how much different that is height wise as these steps are 5" lower than the standard steps.
17" to the OEM step, 25" to the trim
12" to the PRB step, 5" lower
After wrap :love:
Normal chrome
I hope once I get done, mine look as good as this. I too have a level only and 34s. I too do not want the chrome! What product or can you send a link to what you used to go black? BTW, how is it holding up (if not too soon to tell)?
79
4,921
5,117
2022 307a PB, Mach E GTPE
Here's a few issues w/ factory boards on XLT w/ out the seats.
-XLT can't program the software of the DSM until the mothership acknowledges its present which happens when they OTA something to you after DSM install. You'll likely need a 3rd party to program the initial DSM software (factory new components don't have base software loaded). If you have the seat harness plugged into the DSM and loose, you can use someone's DSM equipped truck to do it, just unplug their seat and plug in the DSM+harness for the initial software load w/ FDRS. (a 5.0 401 tremor was able to run initial program on DSM - Forscan cannot program DSM, jesse likely knows more - my 22 302a PB would error out in FDRS for initial DSM programming, however used DSM on used seats was plug and play)
- Non DSM seat heaters are keyed differently AND they run to different locations (DSM trucks, DSM powers heaters, nonDSM truck HVAC powers heaters). You will have to tear apart your factory seat harness, specifically the seat heat wires running to the main seat connector that feed the heating elements and swap them into the new lower seat harness to retain heat. You can't power the driver's seat heat from the DSM without disabling the passenger seat heat. They both get power from the HVAC or the DSM, not mix/match.
- DSM requires MS1 bus, easiest access for tapping is C212. Tapping DDM for MS1 is difficult access due to its location up behind IPMA and dash being in the way.
- DSM powering -- You can tap driver's seat power wire for DSM power, not suggested for boards + DSM powered heating. Driver's seat power + seat heaters in XLT are powered from 1 40a circuit that splits at C265 (one wire to d.seat, 1 wire to HVAC for seat heat). DSM trucks get 2 40a circuits (including the driver seat 40a). DSM + MCS use 2 40a circuits + MCS 30a circuit (MCS fuse/wiring not present in XLT, I used sunroof circuit for MCS, must be hot all times else it will drain 12v batts, been there done that). For BCMC fuse box constrained trucks, passenger seat power can power both seats movement motors, and driver's seat 40a circuit can power DSM. However the BCM can have the sunroof circuit tapped for 30a circuit if the truck doesn't have one. The snow plow / rear seat heat 20a keyed circuit is present in my truck, just a data point, not applicable here (I put a 5' wire pigtail onto that circuit for future 20a circuit keyed expansion). DSM and seats are always hot.
Iceman2022
Jake
Nov 7, 2022
60
33
2022 F150
Controls Engineer
Wooo, I am glad @HammaMan handled the scientific explanation. I myself wouldn’t suggest doing just the running board upgrade. I thought the running board upgrade was relatively easy, but that is because the cooled seat upgrade was so difficult. If you are not going to do the seat upgrade, I would look into buying an AMP research controller. I found a few links to people that got OEM steps to work with AMP controllers.
ReverendQ
Kevin
Mar 26, 2023
198
214
SoCal
Website
www.linkedin.com
Thanks @HammaMan ,
I jumped the gun and ordered the F250 boards/motor and the DSM. I just updated all modules with FDRS last weekend so I would imagine it may be a while before I will get any OTA that might recognize an installed DSM. Also, I do not have access to another truck with a DSM.
At this point I am really hoping Infotainment harnesses take care of the wiring needed that maybe I can talk one of you fine gentlemen if not @Jesse-Infotainment into programming my DSM?
Do you know if ever there was a 302A with PRB that I can get 744 AsBuilt from?
Thanks @Iceman2022 , Yep, me thinks doing the seats first may end up being best course of action as I am not interested in AMP Research hack....yet.
79
4,921
5,117
Don't forget you need the DSM mounting bracket, it doesn't come with it and 4 M5x14 screws to install it W506963S424.
You don't need an asbuilt for the DSM. If a truck w/ boards programs / PMIs it you're all set (will be plug and play into your truck. They issue is getting the initial software program onto it. The kick switch may need to be disabled, though I don't believe that's needed.
