scott011422
Yes and no. Lets just say yes, After letting the vehicle sit for an hour the SOC's should be about the same. And being they are connected together they will receive the same charging rate. But the amount of charge required to fully charge each battery from that resting voltage is not the same.Given the batteries are always connected together, their SOCs shouldn't deviate unless one is defective. The fan 5 trick is very much still alive and working.
For instance, 11.75v is the median voltage for an average AGM car battery. For my batteries, at that voltage, Its going to take 40ah of charge to fully charge the underhood battery and only 7ah to fully charge the AUX battery. So with both batteries tied together, how is ford going to continue charging the underhood battery when the AUX battery charges 6+ times faster and reaches fully charged? They cant. Battery hits full, Voltage rises and charging ends.
I'll check the fan again. I know last I checked after that BMS update running the fan above 5 was not having any real effect anymore.
***Edit***
Fan was set to 6 on our 2 1/2 hour trip last week and was hitting 12.75v. So definitely not working.
