scott011422
I've been trying to figure out these AGM batteries. The electro-chemical potential of a lead acid battery at no load is ~13.2 VDC.
This its fully charged terminal voltage. I have charged up an AGM battery to 13.2 VDC. It then ran back down to 12.6 VDC.
I've then taken a fully charged AGM battery out of the truck and observed its terminal voltage on zero float: 12.6 VDC... Not connected to the truck electrical system or anything. It stays stable at 12.6VDC... What gives? Anyone have an idea
Gros, I was re-reading this post of yours. This part i seperated, Was this in the truck?
If it is, Everything you are seeing is probably normal. There is alot of posts in this thread, But our trucks don't keep the battery fully charged. And if you are not driving more than 15m, Its probably lower than that. I've seen my battery as high as 12.83 with my SOC set at 95%. However once it hits that point the truck normally runs the battery down to 12.49 before it starts charging again.
